What Did You Do with Your 80 This Weekend? (36 Viewers)
She is beautiful........both your daughter and cruiser. In case you haven't done so already, go to your local Walmart and get 2 shotguns, one for each! :p
Had my 40, and I'm not talking cruiser, on me.;)
Matt, the wheels are exact same diameter, just 1 or 2 mm thicker
The airbag wires
Wow, Is the SC400 wheel roughly the same size as the original 80 wheel?
Lfd, the 2 Wires coming out of the airbags have different plug ends I'm sure I could have unplugged it from the bag and plugged it into the spools yellow wire .
or it can also be cut and soldered to the spool yellow wire
Also drilled some 1 5/8" hole in the new bumper and mocked up a comp 4x4 spindle for my soon to be swing out :)
I'm done for today too tired where is my coffee :D
sorry about pic quality, it was dark
What would hooking up the airbag take? Plug & play?
Trying to chase down a P0306 code that suddenly appeared with along with a misfire, on my 97 LC. Doesn't miss when started cold, only after warming up. Guess I'll be pulling off the intake plenum to gain access. Does anyone know the color of the #6 injector wires, or where I can get an electrical schematic.
Pulled my 25 foot sailboat on the trailer out of the water, up a sand bank, 100 yards along a sand bar, then through a stream and up a boat ramp. Really should have yanked the boat before they let the water level down for the winter...but it was pretty awesome!
You should've gone with "Clearly your camera's calculations are off. I'm running 35's so the rolling diameter is larger than stock which means I'm actually only going 35 mph." Guarantee it would work. :)
It's illegal to have a speedometer that doesn't work properly in my state. Idk about AU, but I assume so bc their laws are crazy strict over there. So then he'd be setting himself up for 2 citations. I know you were kidding but it's mud so we have to keep it technical haha.
These are from a couple of weekends ago. The inaugural ride of Crazie Eights. CE is an 80s fellowship centered around N. Georgia. If you live, or ride, around our area, please contact me. IMG_5675[1]2nd edit.webp IMG_5672[1]edit.webp
New steering damper today... Ball joint separator, torch, and a few taps from the hammer. Installed an AC in plug a few weekends ago so that I don't have to run the cord through the hatch seal.
You missed the joke! The joke was that THEIR camera/laser was off because of the oversize tires. Not his speedometer.
And it's illegal here in Iowa as well but that hasn't stopped me the last 22 years. ;)
