What Did You Do with Your 80 This Weekend? (85 Viewers)
Put it off for like 4 or 5 years, but finally dyed my dash mat. Cut down on the glare of it’s reflection on the windshield.
I have an idea, what about the upper third belt hole. Could you make a cover that would insert through the bolt hole and cover that whole area? Kinda like the black front door triangles that cover the mirror access?
Like this?
Will not, need 17s. 16in tire availability is dwindling
Yes it is. When the ole 81 needs tires next were moving to 17s
Oem t4R or taco take off wheels with a 1” spacer
He said has good fitment, any wheel you have to run a spacer on doesn't have good fitment
I have the same cover and was contemplating the same course of action. what dye did you use? How long did you let it soak?
I used 1 whole bottle of Rit brand in approximately 7gal of (nearly boiling) water. I had it soaking for about a hour and I stirred and moved around often. I advise cutting a number of holes in the backside to help stop if from floating. It holds air extremely well. About like a canvas tent it was very hard to pre saturate it with water.
It also shrunk a small amount lengthwise. I did not put it the dryer.
Anything that doesn’t require spacers?
There's a thread of wheel tire combos in the 80 section. There are a s*** load of good 17s that fit these. The lug pattern is ultra common.
Some of my favorite brands
What’s a good quality 17” wheel that has good fitment?
I’ll upgrade soon. My shortlist is KMC and Evo Corse. I’m going for a 17x8.5 or 17x9 et-10 for just a little bit of poke.
Other brands with good fitment I’ve seen: Fifteen52, Battleborn, Raceline, Method, RRW. Though I’ve seen a few method and RRW wheels that need some machining on the hub area to fit on an 80.
RRW have some of the best looking wheels lately in my opinion. Almost bought some for my Tundra but they didn’t come in the offset I need.
Those look great! I almost sprung for those about 3 years ago, as my right hand drive Aussie import has the same interior. But I ended up balking at the price tag and got Cover Craft instead. They've been good, but already starting to fray a little on the driver's side edge. They've probably got a couple more years in them, and then I'll likely spring for the Escape Gear after all.
The EG covers fit just OK. Looks like the covers will not connect at the back of the seat on the bottom by about an inch to an inch and a half. I bought a roll of hook and loop velcro and am using that to tighten things up. Maybe it just needs to conform to the seats a little more. Really nice product though, its great for preserving the fabric.
@Dusten
@ikarus
You guys are amazing. Thanks for the advice.
I have 2 sets of oem wheels freshly powdercoated. I love the oem look but if 17s become more functional (which is what it’s looking like now) I might just go that route.
Yeah it's tough moving on from the stock wheels. Some vehicles it's a no brainer but 80 wheels are great.. light, strong, almost indestructible it seems like, good looks. Tough to beat that with aftermarket
