What Did You Do with Your 80 This Weekend? (54 Viewers)
I got 04111-66061 from partsouq for about half the price as the fzj80 version , including shipping. It comes with everything you need.
I think I got the idea from @SNLC or @COYS not sure, but it's been discussed thoroughly as mentioned.
You did well, david. All credit goes to SNLC. He's a great 80 resource here. Gracias.
Didn't you just rebuild a motor and swap it into your rig?
Do you have multiple cruisers?
Yes I just rebuilt a motor for my cruiser. Im on
Cruiser #3 now this one will be for the wife probable or maybe just sell. I really like working on cruisers it would be my job if it was viable! But I have a career as a plumber so for now it’s just a side thing.
Yah @COYS let me know I ordered yesterday looks like lead time might be a bit🤷‍♂️. Either way it $100 cheeper than the other kit.
Boring stuff today. I vacuumed the interior.
Beach day with my daughter before she leaves for college
FYI, if that is the coil pack 1FZFE gasket kit there are a few gaskets that won’t work and will have to be ordered separately. Still cheaper in my opinion.
Cheers
This is all OEM from Wits' End and followed FSM.
I was reading up on the nut Gs and decided they weren't necessary for me. Best way to handle it is to routinely check them as part of general maintenance.
The torque is 71 ft/lbs
Is that the torque for the stud going into the housing? Or the torque for the nut on the stud?
The nut. Studs rarely of ever have torque.
Arp head studs are finger tight.
Beno advised a stud torque a while back when Toyota introduced a superseded stud for these trucks. The new studs come with Loctite compound on them and they are advised to torque to 35 LB-FT I believe. I would have to find the post by Beno to confirm.
Studs 35 LB-FT
Nuts 71 LB-FT
Make sure the cone washers and flat washers are installed and DRY, not greased or oiled.
Found it: (Post #37)
36 LB-FT
Studs 35 LB-FT
Nuts 71 LB-FT
Found it:
36 LB-FT
That’s what I was looking for. Thanks bilt4me
Studs 35 LB-FT
Nuts 71 LB-FT
Found it:
36 LB-FT
I did say most. I might tear mine apart and torque them now.
I was criticized for torquing mine to 45 LB-FT and using red Loctite.
Then it turns out I was pretty damned close and they added thread locker.
I have not had anything come loose on mine in 130K miles of DD.
What size are those studs?
