What Did You Do with Your 80 This Weekend? (50 Viewers)
Were you able to get the old window out and put the new one in alone? I have a set of these that I want to install, but I am concerned that I won't be able to do it alone.
just so you know the rear sliders go in and out easily. its not hard at all.
Can one person do it? I am worried about getting it partially pushed in and then climbing inside to pull it the rest of the way in and having it fall out while I am moving from the outside to the inside.
Yes but 2 people do make it easier as does warm weather.
Thanks! I did watch that video and I was planning on buying those pry bar things from HF. He just didn't go into the reinstall, which is the part i am worried about. If the old ones break, so be it, but I would rather not bust the new ones I just bought from @slow95z.
actually LCP left thevideo same one I used, I thought out of all the work Ive done by myself this was really easy and the window dont weigh much at all.
I did the removal video. The install video is for our Gullwing Flip Out Windows. ;)
When you install the factory window do make sure the glass is closed to avoid bending the frame. There are a lot of unused rear windows available so I would not worry much if you damage one.
Ah, that makes sense. I will take a look at your install video and give this a whirl soon. Thanks again!
What did you do with your 80 this weekend: maintenance, fix, wheel, nothing, new mod??
Me:
Checked air in tires
Change oil&filter 180,000
Fill gas tank
Waiting on box of parts from Beno
Still baselining our recent acquisition.
99% of the cooling system. Radiator to fan clutch to sensor. Water pump to pesky heater hose.
The only things I left alone were the heater valve & rear heater hoses. The valve I forgot to purchase. Rear hoses I bought even though mine still looked great.
Did you mod your fan clutch prior to installation?
You can do it without prybars if need be
To be honest I did not. Sister and brother in law work at a Toyota Dealership so when I pulled the rusty Borge Warner fan clutch the previous owner must have had installed I just used my sis's discount and went new.
Even a brand new fan clutch will benefit from a fluid change if you live in an area where it hits 100°.
Fired the ol girl up for the first time in a couple of months! Drove it all the way outside of the barn. I have my daughter's winter tires on it to move around. Supposed to have brand new 35" KM3's on my CE stock wheels tomorrow.
I decided that as much as I love white Cruisers, I hate the faux wrap more (mostly because it was a sh*tty job by me). Started the peel off and going with the original Desert Dune.
Gotta lose the "supercharged" emblems too- since it isn't now
IH8MuthaFawkingMoonroofs
Sized up the 24gal LRA aux tank and swapped out the beat up tough dog for a king stabilizer. The toughdog was better for oversized tires. @wardharris
