Naw, you haven't driven our Tubos yet.... And longevity wins here. Let the debate begin😎
I mean...ok... I will take the bait. 🤪
Crazy to think a high-stressed turboed 1FZ-FE, running on the edge what a first generation OBD II ECM can handle, can outlast a normally aspirated LS V8 like my 2020 Gen IV L96.
Take a close look at a 1FZ-FE and look at the number of old-school Vacuum Switching Valves (VSV) and the vacuum lines that go with them. There are zero on my L96.
Look at the number of cooling lines (hard and soft) on a 1FZ-FE. A LS motor just has the upper and lower radiator hose, two heater hoses, and a steam port line.
1FZ-FE isn't even running a Multi-Layer Steel HG, while LS engines are. I mean, the 1FZ-FE will blow a HG if it gets a tiny bit hot, ...an LS has to be much much hotter for it to blow a HG and then it most likely won't be catastrophic due to the HG being MLS.
I have yet to see a 1FZ-FE hit 500,000 miles without major issues. I assume they are out there, but I haven't seen one. Most people posting here with major engines are about 350,000 miles or less.
Background on the L96
The L96 is found in GMs 3/4 and 1 ton vehicles.
Isuzu offered it in its commercial truck division on the NPR-HD for nearly a decade until they switched to the successor, the L8T.
The L96 was also used in the marine industry, which is crazy demanding, where engines could run wide open for hours. Forklifts the same as boats? IDK. 😁
The L96 has been called the "expedition motor" due to its reliability.
The L96 is known, with heavy abuse by general contractors and poor maintenance, to make it to >400,000 miles and many have done over 1 million miles.
I will take my Gen IV L96 over a turboed 1FZ-FE all day long...not even close. 😁
My 2 cents....all in fun. 😉
I will be at Cruise Moab and Rubithon this year if anyone wants to check out my LS Swap.
I’m on the fence
Not sure if I like the sound of turbo spooling up or the sweet sound of a V8 better.
Don’t really need either for the slow speed rock Crawling that I do !
Doing a little fan clutch work.
It is an interesting consideration between the two. For me it depends on the starting spot. In my case, I would, at minimum need a top end refresh as I’m approaching 290k on an OG 1FZ. Add that to the stage one turbo and intercooler, because I think that would be best practice, and I’m getting easily into that LS 6.0 6le80 range. So, given that, I don’t think there’s much real debate beyond keeping things Toyota. Upsides: run any grade fuel I can find, get parts at every backwoods shop I might find, and have gobs of power right off the line, no waiting for turbo spooling. Hard to pass over the LS when approached from that point.
Looking forward to seeing it at Cruise Moab!
For me, mine is in great original condition, and with 165k on the clock now, I know that I'll have major services due soon. That said, I really like keeping the original power plant in place for originality. My only real issue is getting to the trails...it's a long ride on mountain passes. Once I'm there, it'll crawl all day long with ease, especially with my updated gearing in diffs and transfer case.
At this point, I'm super excited about the @Cruisers and Co transmission upgrade as I feel that it will get me in a much better power band that the 1fz can manage. Once I get to 70+, I can cruise all day with comfort, but throw in some grades and it all goes to crap. Fingers crossed as I'm already starting to collect parts for the trans swap and excited to see the C&C rig at Moab too!
Finished the Transfer case rebuild with the 3.15:1 low range gears and 10% under drive gears. About as difficult as I thought it would be but took me longer than it should have because I kept second guessing myself and went back to the videos to make sure I was right.
Looking good! Did you have to adjust your shims that I mentioned last week? Just curious as mine took quite a bit over the stock center diff when I switched to the PT spool.
I did have to adjust one of them but I had to take one out. One shim stack was measuring at 0.84 and the other was measuring at 0.43. The pre-load feels right to me but only time will tell at this point.
What transmission are you going to?
The 100 series A750F 5 speed conversion that @Cruisers and Co is putting together.
Very cool. I read that whole diary post but didn’t see any pricing. More curious than anything as I’m already pretty deep into my 6BT/NV4500 swap.
I’ll jump in on the LS vs Turbo debate. Both are great options for the purpose of increasing the drive ability of the 80 series. This is fact, no debate there.
Please take into consideration I have done both at the professional level.
In an OEM to OEM application I think the LS has an edge in reliability (talking purely about motor here) but we aren’t talking about OEM applications here so that reliability argument is not necessarily true.
There are cons and pros to both options and I think the biggest curveball in the whole thing is installation.
Installation/reliability:
I would argue that for the most that the turbos come more reliable out of the box because 99% of the system is still oem Toyota and as long as the engine and cooling system are healthy - which most individuals going turbo have already addressed at some point, especially if the head gasket has been replaced with the newest iteration. Most individuals (generalization here, definitely not everyone) doing an LS swap into their 80 are likely first timers watching YouTube videos or browsing the forums to finish. They cut corners (mostly by accident, just first time ignorance most of the time), are doing it on the cheap because they need a power plant asap and are rushing to get it done. I have seen 100’s of V8 swaps done by the DIY/professionals in cruisers and there is always something that is not done well or becomes a problem later. Wiring, plumbing, exhaust… there is always something that needs to be tweaked or fixed or updated. Case in point (sorry Daniel) but did anyone see Long Cruiser’s posts about coming back from KOH??? Hits Green River UT and lost the transmissions due to poorly routed transmission cooler lines in his LS Swapped limo. I have also seen professional swaps have electrical issues. We were on Kane Creek at Cruise Moab one year and his turn key professionally installed LS swap from a really big well known resto shop kept going into limp mode every couple miles and we kept having to unhook the battery, touch negative and positive leads together to clear the memory so he could move forward. Almost every LS swap diy or professional has something that needs improved once it’s been installed. I have also had to go back and tweak things on LS’s I have done.
Going away from the oem decreases the reliability of the truck.
Since I’ve turbo’d my 80 over 3 years ago I’ve done oil changes, my clients have done oil changes. That’s about it for maintenance that anyone has done. Maybe an improved fan clutch which is easy and new exhaust which likely needed done anyways given the vehicles age. It’s also a much easier install for the diyer and professional. Also the confidence with the turbo systems is high. Last summer we got a truck running with a rebuilt (by us) engine with a turbo 3 days before we had to leave CO for Rubithon… ran the trail without a hiccup besides busting up some control arms 😂 most of you guys aren’t going to the rubicon 3 days after finishing your LS swap.
Cost
DIY - Hands down goes to turbo. You aren’t doing a proper OE level LS Swap for anywhere near the cost of strapping on a turbo.
Professional
Cost still goes to turbo. We can rebuild the 1FZ - Add a turbo - add an intercooler and a transmission and be below what I charge for an LS Swap. Plus all the factory electrical stays Toyota (assuming 95-97 stage 1)
Performance
Depends what LS you use but generally LS wins this vs a stage 1 turbo. The stage 1 turbo is generally like putting a 5.3L under the hood. You gain 65 hp and 100 ftlbs to the ground. Go to a 6.2 and LS is making more than the stage 1. Stage 2 turbo, more power than a 6.2. Also fwiw most people who have driven or ridden in a stage 1 turbo truck say it’s enough power for them. I can keep 70-75 up any grade with stage 1 turbo (this has been well tested on I70 going to the Eisenhower tunnel (11k ft).
For the guys convinced that LS is the only way… it is a great option. Truly it is.
For the guys convinced that turbo is the way… it’s a great option. Truly it is.
Either way you slice it getting away from the OEM is going to have its own challenges. Both are great options and have their place. Really comes down to the end consumer and the wants vs needs. I wouldn’t say one is better than the other, both are proven.
Cost
Professional
Performance
If I'm not mistaken, you left out one key detail: your turbo kits are CARB compliant.
They aren’t… but they pass CO emissions and run cleaner than a factory truck 🤷‍♂️. That last part is what pisses me off about CARB.
Also on the sound of the two… while LS’s sound great… a 3” exhaust on one of our turbos sounds epic
