What did you do with your 60 this weekend? (15 Viewers)
Took the Husky out in the 60 to pick up her new German Shepherd sister!
The inaugural Sixty Shindig in the desert! 75 degrees, 12 super cool folks, 8 sweet 60/62’s, 5 four-legged furrballs and one blown out tire. New friends were made, lots of firewood burned and all bellies filled w legit Carne Asada tacos!
View attachment 3879519View attachment 3879521
Next time...
Plowed field, 3+ inches of rain = stuck
First attempt at unstucking was using a Kubota tractor to pull out the 60. Tractor almost became stuck so I then used the tractor as an anchor and routed the winch line underneath for a backward pull. Warn 12K winch.
That didn't work. I then employed the 80 series with a Warn 10k winch but had to anchor it to a tree.
Using both winches finally extricted the 60 from the mud.
Second skin damplifier pro -> second skin luxury liner pro -> @dnp carpet kit. Some remove the jute from the carpet before install. I kept mine. And I left my factory sound deadening in there. Just pulled out the old carpet and cleaned out all of the old stuck on jute and went to town
Hey, what did you use to get all the old jute off?
WD-40 works very well. It breaks down the glue and then you can basically just wipe that old stuff right off.
I'm just gonna leave my factory sound deadening in there. The new stuff sticks to it just fine and its in good shape but the jute from the carpet padding stuck allllllllllll over it.
WD-40 takes it right off. Picked that advice up somewhere in the 60 Series forum and can confirm it works. Yes, it leaves the smell behind, but a little soap and water sorts that right out.
I actually used one of those gloves for brushing hairy dogs to get the big piece of jute off. Then just used dry ice for the remaining jute and hard stuff combo.
I used a steel welding coarse bristle brush from Harbor freight. It’s the wooden handle one with the steel bristles that costs like $4. Pulls it all right off. You have to unclog the brush quite a bit though but it works
