What Did You Do With Your 120 Today? (11 Viewers)
Could be. Mine didn't look great, but I'm sure there are worse:
I'm very lucky to have a west coast car; the LCAs dropped out without a fuss. No rust. I had bought new cam bolt sets but ended up using the originals because they were clean and much beafier. Still debating what to do with my old OEM LCAs.
@DRANGED @runningdrew Found this on another thread with a post by @coops2k to give you some more ideas about a rear release;
Thread- Sleeping in a GX
Front DS axle seal gave up the ghost on me ~2 weeks ago so, tired of seeing gear oil in my driveway, towed it to Mr. T down the road today and had it repaired professionally. While in there, and since I was already being lazy and not doing any of my own maintenance, I had them do my TC and rear diff oil replacements as well. Expensive day but this wasn't going to get done any time soon given my busy schedule.
Discovered that the fog light on the driver side wasn't turning on, another item on the list when snow stops blowing into the garage.
Also made this soft shackle. I needed a little more length as it turned out to be a little shorter than desired. Oh well, makes great practice.
Picked up the GX from the shop after a repair last night. While I was hoping the bearing noise would be warranted, the noise was from the belt tensioner assembly. After 160k, I guess thats expected a little.
Also made this. I need to apply the whipping line but almost completed.
I installed a small leveling spacer up front. Other work continues in putting other things back together. Still need to find the best way to prep and color match spray a black front bumper I found locally...?
1903827
Still looking to buy roof rack end caps from anyone that has replaced their factory roof rack.
do you have masking or trim lines to "lighten" up the angles when you put those bumper skins back on?
Ergo, are you going to trim them up a little?
I'm 50/50, I was going to 100% if I had tried to salvage my mangled front bumper cause I had nothing to lose. Almost tempted to try with old bumper, pull plastic from running boards to fill in some missing chunks of front bumper that the fence post chewed out.
Or mask and paint the fender flares and body cladding black, ergo 2-tone ;)
Did someone say two tone? ;)
HAHAHA!! YES, thank you!! I was digging and digging to find when you did yours. ;)
best I could come up with in last 20 min was this...
1903893
I swore you'd talked about going tan, but did you just do the black and stayed pearl?
How did you get in my living room?
vicariously? ;)
Methinks you should look into the black Prado window treatment (black vs chrome).
Moulding, Quarter Belt, Rh, Toyota
75660-60050 US $17.92 1 pc.
Moulding, Quarter Belt, Lh, Toyota
75670-60050 US $17.92 1 pc.
Moulding, Front Door Belt, Rh, Toyota
75711-60061 US $17.84 1 pc.
Moulding, Front Door Belt, Lh, Toyota
75712-60061 US $17.84 1 pc.
Moulding, Rear Door Belt, Rh, Toyota
75721-60061 US $22.97 1 pc.
Moulding, Rear Door Belt, Lh, Toyota
75722-60061 US $22.75 1 pc.
