jblueridge
I wiped off the bumper and stuck stickers and badges on.
It kind of depends....I think @cruiserdan had to modify his battery bracket slightly to fit. These brackets are probably 1/4" extended down due to the new material vs. the older style that was bolted/riveted to the hood. Perhaps @cruiserdan can give us some insight.Will they work with the dual battery set up?
I have have tried mixing Rustoleum with the paint hardener sold at Tractor Supply. It helps it set a little faster.
Any Gladiator or Trail Rated t-shirts?Took the Camper truck to a local event....southeast overland expo... this weekend. Cool event....had a neat off road course, vendors, camping, all that stuff.
Saw a 70 on the way home....
Oh I'm sure. Surprisingly, I think there were more Toyotas than anything else.Any Gladiator or Trail Rated t-shirts?
Things are slowly coming together with the TD04-13bt. All the main components look good, just waiting on the new intake and charge pipe hoses along with the oil lines. Other than that I'm hoping this should be pretty straightforward. If all goes well I’ll probably figure out an inter cooler setup.
I’m not sure what was on prior I think maybe 2.5 or 2.25 but I’m going to run a 3 inch exhaust unless anyone thinks 3 inch will be unnecessary. I just figured since I’m going to be doing a new turbo setup I might as well take the time do the whole exhaust.Looks good!
Do you have a bigger exhaust on there? What size is that?
So I did and will again redo the exhaust on my BJ73 I have a couple of comments. I'm going to assume that your exhaust is like mine it exits between the fender and top of the frame in right front wheel well then rides between the rocker and frame rail and goes over the frame rail aft of the right door, crosses over the driveshaft and out the back on the left side.....In this pic of another 70 series you can see where the exhaust goes low. With some cut and mod on the exhaust hanger on the frame you can get it up higher and out of the way.I’m not sure what was on prior I think maybe 2.5 or 2.25 but I’m going to run a 3 inch exhaust unless anyone thinks 3 inch will be unnecessary. I just figured since I’m going to be doing a new turbo setup I might as well take the time do the whole exhaust.
