Want to know the best way to go about this straight pipe. I plan to have a local shop use 2.5" from the remaining cat back. Is it possible to eliminate the cat and still have the 02 sensors operate and have the engine run well? No motor mods or performance equipment installed yet
You can do it but you will set a continuous O2 CEL. You could use one of the many O2 sensor cheats out there. You won't gain much if anything in stock form unless your cats are clogged.
It doesn't sound nice. My truck had the exhaust flange break off the muffler so I was cat-back straight pipe for a couple of drives. An inline 6 just doesn't have a good exhaust note IMHO. Seemed to have less power with the open pipe than I do with a full exhaust system.
Depends on the year. 91-94 are OBDI, so only have O2 sensors pre-cat, so you can weld in o2 bungs into the exhaust. 95-97 are OBDII with sensors after the cat, so will throw a constant code.
You'll want something in there (muffler, resonator, both). I deleted my cat, but think I need to add a resonator. Sounds pretty redneck right now.
The tail pipe rotted off and there is a super budget muffler installed now. All the hangers are rotten or gone so a full system would have to have all those reattached. Just looking to simply route the exhaust and not spend a fortune
I've always liked the sound of a V8 with short / free exhausts but the 6 is just not the same. My old 390 with dual magnaflows sounded amazing, at least to me and everyone that within two miles that could hear it. If there are ideas to get a nice reasonable burbly sound out of the 6, I'm all ears. pun intended.
Mine just runs straight next to the outside of the frame and dumps right before the rear tire. Not great, but was cheap and allows me to hear the engine which was the goal. I do wish it was lower pitch but maybe even just a larger diameter pipe would help.
It's an off-road vehicle with a forklift engine, not a supercharged V8 in a sports car. Trying to make it sound like one is like trying to get blood from a stone.
no cats- y-pipe post o2 sensors on 94.....to 2.5"- a little too much flow- added a ducati adjustable flow restrictor and power came back as well as allowing backpressure to make straight thru mufflering work. straight thru with 2.5 didnt have enough backpressure to allow muffler to work effectively. lots of drone prior to restriction. this is a 26" -4" diam. muffler
