It's possible you have an injector that's faulty. 4 years is a long time if the injectors had fuel sitting in them.I don’t know how long it sat before I bought it but from the time I purchased the engine to first start it looks like 4 years.
The first few gallons of fuel that I ran through the engine had fuel system cleaner it it with those in mind. The primary reason I have not pulled the injectors to have them serviced or replaced is because the lean codes are for both banks, O would have thought if it was just one or two poor performing injectors the codes would be specific to one cylinder or another. Please identify the flaw in this thought process.It's possible you have an injector that's faulty. 4 years is a long time if the injectors had fuel sitting in them.
There was one capped port in the back but I used it to hook up to the brake booster. There are a couple vacuum lines on the bottom but they are hooked up as the should be. There were zero leaks detected from brake cleaner and smoke machine testing on the planum ports.Some uz’s have capped ports on the back of the intake. Sure those are all good?
The planum and exhaust manifold gaskets were replaced with oem parts bought from parstsouq ( I am not aware of any reports of them selling counterfeits). When I test for leaks around the planum by plugging and clamping lines individually, using brake cleaner and last using a smoke machine I did not find any leaks from the planum or ports.Maybe worth pulling the manifold and checking the gasket. I’ve seen aftermarket ones that don’t seal for crap. Usually you would have a purge valve code too. But can pinch that line and make sure it isn’t the culprit that something else we see a lot.
Maybe it was too soon for me to recommend the injectors as suspect. If you clear codes and drive it with live data on, when do stft numbers go above 5?The first few gallons of fuel that I ran through the engine had fuel system cleaner it it with those in mind. The primary reason I have not pulled the injectors to have them serviced or replaced is because the lean codes are for both banks, O would have thought if it was just one or two poor performing injectors the codes would be specific to one cylinder or another. Please identify the flaw in this thought process.
I was trying to capture more live data last I drove it with the oem filter box on but the program kept loosing connection, I suspect the cable usb plug was getting josseled. This is the only screen shot I got. i might have been going about 30mph at the time.Maybe it was too soon for me to recommend the injectors as suspect. If you clear codes and drive it with live data on, when do stft numbers go above 5?
Good question, I don't own a gauge to test this, so I have not. Maybe another tool I need to purchase.Sorry did not read all the prior pages to know. Is you vacuum on FSM spec if you use a vacuum gauge?
@RivMan
- Engine was purchased November of 2020, first start Octoberish 2024, reported to have had 106,XXX miles on it
- Engine is out of a donor 2006 Land Cruiser, although partsouq dates the vehicle as 06/2005
- Engine Harness came with the engine, I sent the harness and ECU to a vendor to have it built into a standalone and have the ECU reworked. The vendor cooked the original ecu and replaced it with a 2005 GX470.
- The ECU was flashed and some systems were deleted, the transmission was deleted since I am running a manual transmission. I understand that it is wired such that the ecu believes it is in gear.
- The SAI system was turned off inside the ECU (I get no codes) and I deleted all the components related to this system. The holes for SAI tubes in the heads were threaded and plugged.
- The Second 02 sensor in each bank have been deleted
- The cats he been deleted
- The EVAP purge valve is intact and plumed to the charcoal canister which is connected to the tank. I capped the evap line to test it a vacuum leak source. No change.
- The PCV is also intact and I tested it as well as source for the vacuum leak.
- All replacement parts installed were purchased from Partsouq using the vin number of the engine donor vehicle: MAF, PCV, Planum Gaskets Manifold gaskets, A/F Sensors, Hoses, timing belt, spark plugs, crank sensor, other parts as well but they are not specific to this issue.
- The brake booster is stock for the 91 land cruiser and the vacuum is connected to a port on the back of the planum. I plugged this during my search for vacuum leaks as well.
- The air filter box is from a 2005 LX470, the intake pipe I have I believe came with the donor engine.
I have been enjoying your build thread and will throw out a few thoughts I have. Thanks RivMan for asking for a rundown of your setup because it is helpful to see to provide input. There are two things that jump out to me.
Is the issue fuel supply related? To my knowledge the VVTi Land Cruiser has a returnless fuel supply setup (meaning no return on the fuel rail) and the fuel filter contains the regulator. How is your fuel supply and return line setup compared to how they would be in the donor Land Cruiser? Also, the 2uz VVTi variant typically has a fuel pump control module. Do you have that in your system or how is that addressed?
Is the mix of 05 LX470 ECU causing an issue because of a slight difference compared to the Landcruiser everything else? And I assume it is a model year 2006 LX470 in order to be VVTi?
The builder doesn’t believe there is anything wrong the ecus. I need to send one back for an adjustment but I not there just yet.Your close Dennis. ECU ship and reset is an easy card. Entirely possible something was missed. Dont the front 02 sensors pick up lean codes as well?
