- Thread starter
- #41
Cool to see that you are doing a similar build, but on a different chassis. Based on my understanding the 1UZ vvti is basically the same as the 3uz. The 3uz is just bored over for larger displacement and has some updated parts on it.Awesome build! Glad to see how you placed your cowl relative to the frame as I'm facing a similar although fairly different build, 4runner chassis instead of an 80 and 1uz instead of the 3uz, although I am going R151.
Question for you, what fly wheel and clutch combo did you go with?
I have been waiting on a flywheel that I ordered close to 3 months ago... It is a flywheel that Northwest Toys sells that LCE Performance manufactures. It is essentially a 3vz flywheel that is heavier weight and milled to fit the UZ. Based on the reading that I have done, a good machine shop can mill a regular 3vz flywheel to fit the 1uz. The clutch I have is also from Northwest Toys and is an LCE clutch with the correct throwout bearing for the UZ - it is basically this clutch (Dual Comp Clutch Kit - 3VZ(88-95) (9 1/4'') - https://www.lceperformance.com/Dual-Comp-Clutch-Kit-3VZ-88-95-9-1-4-p/1053090.htm)
Since you are in Zimbabwe, I would see if getting a setup from Castlemaine Rod Shop in Australia is reasonable. Or it seems like a lot of 4runner/Pickup UZ swaps run the KSracing kit sold on eBay. I think the black bell housing that I have (shown in my pics) is from KS racing and Northwest Toys basically re-sells it.
