Ultimate OEM 60 series parts still in stock (7 Viewers)
19102-43060.
It's very odd. The Toyota procurement system shows about 45 of them in the US. When you try to order them, they "manufacturer cancelled" due to it now being a non-import part.
Screwed up. Lots of parts are disappearing this way. :frown:
And this is the rotor that's on top of the distributor shaft under the cap?
Will the 3FE rotor interchange with any of the 2F rotors?
Yes, the dizzy rotor.
No, the 3FE rotor is the same as the 1FZ-FE: 19102-61240
That won't be going anywhere for a long time.
Great thread. I'll try to contribute as I get a chance.
One item of recent bad news though: later 2F rotor is now discontinued
:frown:
Once it's gone, it's gone forever? Do they ever start making parts again? I guess it is aftermarket from now on....ugh!
Zack
beno posted the part number required to stay OEM, just don't ask your local parts guy for an FJ62 rotor, ask for it by part number
FJ60 PCV and Grommet
You can buy direct from this dealer (Titus Will Toyota) online at https://www.1sttoyotaparts.com/index.php
PCV PN 12204-61010 is $13.17 Internet price $4.21 (not sure this one is correct because I paid list price today and the list online is $5.03)
Grommet PN 90480-18180 is $3.09 Internet price $2.23
Some other important parts/assy's components for the FJ60:
Air Filter: 17801-61010
Fuel Filter: 23300-38010
Fuel Pump: 23100-61070 Fuel Pump Spacer/Insulator: 90923-06010
2F Valve Grind Kit: 04112-61041
Cylinder Head Cover washers: 90210-13001 (x4)
Valve Cover Gasket: 11213-61011
Head Gasket: 8/1980-11/1984: 11115-61010/ 11/1984-8/1987: 1115-61030
Side Cover/Pushrod Cover Gasket: 11253-60010
Water Pump: 16110-61081-77
Thermostat: 90916-03052/o-ring: 90430-43002/housing paper gasket: 16341-61030
PS Pump Belt: 99343-11570-77
A/C Belt: 8/1980-4/1986: 99332-11250-78 (1250mm)/ 4/1986-8/1987: 99332-11260-78 (1260mm)
Smog Pump Belt: 99343-11120-77
Manifold Gasket: 17172-61041
Air Intake hose: 17751-61030
Ignition Coil: 90919-02113
Dizzy Cap: 19101-61240
Wire Set: 90919-21325
Plugs: 90919-01065
Front Axle Seal Set: 04434-60015
Trunion Bearings: 90366-17001-77 (x4)
Knuckle studs (Torx heads): 90126-12005 (x16)
Inner wheel bearing: 90368-49084-77 (x2)
Outer wheel bearing: 90080-36067 (x2)
Star washer: 90215-42025 (x2)
PS Pump: 44320-60071
Inner axle seal: 90311-33085 (x2)
Diff drain plug gasket: 12157-10010
Aisin hub face gasket: 43531-60010 (x2)
Aisin hub oring: 43532-60010 (x2)
Front disc rotor: 43512-60100
Outer Birf c-clip: 90520-31007 (x2)
Front hub flange studs: 90116-08325
Front brake pads: 04465-YZZC0
Rear brake shoes: 04495-60070
Onur, on your wireset part # it shows it as being for up through 1985. When I tried ordering a wireset for my 87 it said it was discontinued.
Anyone know if I can use this set for my 87?
Thanks,
Matt
Thanks,
Matt
A guy had a new OEM set in classifieds real cheap. I would of bought them but I just got a set from Onur. :hillbilly:
This thread kinda makes me sad......I wish Toyota would keep production in place of FJ-60 parts. I was reading an article about Mercedes Benz, and they will produce any part for any year or model car they have ever made; now that is customer service!!
Zack
OEM Steel Wheels and Hub Caps that fit a 60
Wheel-42601-60072
Front hub cap-42621-60010
Rear hub cap-42621-60020
Standard Toyota lug nuts
Thanks,
Matt
Kind of an EPC anomoly. For some strange reason, the EPC does not show the wire number for 1986-1987 FJ60's.
But the correct part number is the one that shows for a 1985 FJ60 which I listed above.
Luckily, CDan shows me the tricks of trade learned through 32 years of being a parts geek. I only hope to be half as good. :)
By the way, Toyota has graciously re-instated the "big" rotor: 19102-43060 which was previously discontinued to our amazement.
But there aren't many left in the country: maybe about 20 or so remaining in Ontario,CA. I got myself 3 to last me awhile just in case supply runs out and Toyota decides against importing anymore.
This PN is good only through 11/1984.
Mid-11/1984 and later requires 90480-18001 for the grommet.
PCV stays the same.
All the 2F PCV grommets are interchangeable. PCv valve and socket in side cover never change. I recommend the earlier number (18180) because the grommet is bigger, such that it wraps over the top outside of the pipe, providing a better seal against water running down inside the engine.
:cheers:
:cheers:
"I see" says the blind man, "I see"!
H55F Transmission Upgrade
These are the OEM parts to install a H55F 5 spd transmission in a 1987 FJ60. Prices are from a couple of years ago.
33030-60450 H55F Trans Unit - List $2355.55
33124-360010 Oil Pipe - List $1.97
33530-60160 Lever Assy, Shift - List $171.56
33504-14050-co Knob Sub-Assy, Shift - List $48.93
33548-60020 Bush, Shift Assy - List $3.32 (Didn't need came with H55F)
31210-36330 Cover Assy, Clutch - List $188.64
31250-36342 Disc Assy, Clutch - List $100.42
90363-52001-77 Bearing, Clutch - List $76.99
90363-15004 Pilot Bearing, Clutch - List 15.50
90311-99001 Seal (rear main) - List $52.04
Hi everyone,
Does anyone know what the availability is on exterior trim pieces....rain gutter trim? chrome trim around the windshield? bumpers?
Thanks,
Zack
