Previous owner had a fat wife?
A / B springs mounted on wrong side? OME springs are side to side specific as well ....My 80 has a leaning problem. On flat ground the rear passenger measures about an inch lower that the drivers side. I started noticing it about 3 months ago. Other than a blown shock, what else do you all think the issue could be?
Actually, that could do itThe lift has been in for a few years and I just started noticing this about 6 months ago. The passenger side rear lower control arm is slighly bent due to Dickey bell, but I cant imagine that would compress the suspension.
Bruce got a new valve cover gasket!
Pulling the springs, while easy, is tedious and I doubt you will find anything there. Check your rear sway bar. Disconnect it and see if there is a huge amount of tension on it. Sitting at right height, it should be easy to remove, but if it is bent it could be under a lot of tension.The lift has been in for a few years and I just started noticing this about 6 months ago. The passenger side rear lower control arm is slighly bent due to Dickey bell, but I cant imagine that would compress the suspension.
OH man! They have gotten so much bigger! Wow. Anyway, get an old battery powered drill on the rear axle! Convert to powered vehicle, it was Zach's favorite project when he was about that age.Knocked this together with the boys this weekend.
They were having a great time racing down the hill till Dad tried it, got it light on one side in a corner and bent an axle.
On to McMaster-Carr for beefier threaded rod.
just ordered one of these, been waiting for something like this to come around.
FJ80 Delta Panhard Lift Bracket
Review: Delta VS Panhard Lift Bracket
