I started this project a couple of years ago. Some called it the ultimate in turd polishing. Get the comfort and road manners of the 4 speed trans with the retro cool factor of the three on the tree shifter.
Took some measurements. Started cutting blocks of wood. Took some more measurements. Made some more cuts. Third round of measurements and I was ready for an aluminum block to cut. Machined all the rough cuts and then put it on the shelf for the next two years!
Well I finally pulled it back off the shelf a couple of weeks ago and finished it up in anticipation of installing my 4 speed into my 45. Already acquired an unobtanium fj45 tranny hump that wasn't as pristine as mine in case the shifter didn't work out.
Bolted the adapter on and it worked flawlessly! Full range of motion, side to side and for and aft. JACKPOT!
Measured the final assembly for height and figured that it wouldn't clear the trans tunnel in stock configuration. The added girth of the 4 speed trans, coupled with the adapter plate, require 2 inches more than the trans tunnel has.
Therefore, the two choices [if you want to run one of these] would be to cut and raise the forward section of the trans tunnel to create the necessary clearance or...... install a 2 inch body lift!
All in all, it was an interesting engineering challenge, regardless.
Maybe I'll send the prototype to Di-Pro to get a quote on mass production [couldn't resist that one];p
@65swb45 - Mark, does one just install the adapter plate and 3 speed top plate on a 4 speed tranny and away you go, or are there other mods to the 3 speed top plate to make this work? Just trying to get a high level understanding of what is needed with this swap.
