Working on that now. I just really wanted to drive it first.Let’s see how you did the hump?
Im going to upgrade to a 4 speed for the deeper first and synchrosThis is such a cool mod, but I’m still wondering what the payoff is for going from a 3 speed to a 4 speed with the final ratio being the same. Is it just the difference in the ratios of the other gears in terms of drivability?
Thanks Mark. I have a nice spreadsheet, but not sure best way to share it. Considered a google sheets document, but I am concerned that would give access to my other personal files on my google drive.Somebody paste this into the FAQ!
| Toyota J30 | Toyota H42 | Toyota H55f | Ratios | Effective H55 w/ 4:1 split case low gears & 1.1 high | NV4500 | T-Case Low Gear Options | ||||
| 1st | 2.757 | 1st | 3.555 | 1st | 4.843 | 5.33 | 5.61 | 3spd Low | 2.313 | |
| 2nd | 1.691 | 2nd | 2.292 | 2nd | 2.619 | 2.88 | 3.04 | 4spd Low | 1.959 | |
| 3rd | 1 | 3rd | 1.41 | 3rd | 1.516 | 1.67 | 1.67 | Splitcase Stock | 2.276 | |
| 4th | 1 | 4th | 1 | 1.10 | 1.00 | Splitcase 3:1 | 3.1 | |||
| 5th | 0.845 | 0.93 | 0.75 | Splitcase 4:1 | 4 | |||||
| AA rock box | 3.44 | |||||||||
| Effective Crawl Ratio in 1st Gear | NP 203 Doubler | 2.0 | ||||||||
| Diff Ratio | 3.73 | 4.1 | 4.56 | 4.88 | 5.29 | |||||
| Factory Ratio 3spd | 23.79 | 26.15 | 29.08 | 31.12 | 33.73 | |||||
| Factory Ratio 4spd | 25.98 | 28.55 | 31.76 | 33.99 | 36.84 | |||||
| Factory Ratio FJ60 | 30.18 | 33.17 | 36.90 | 39.48 | 42.80 | |||||
| H55F Factory Ratio | 41.11 | 45.19 | 50.26 | 53.79 | 58.31 | |||||
| 4spd Rock Box Only Low Ratio | 45.61 | 50.14 | 55.77 | 59.68 | 64.69 | |||||
| 4spd Rock Box Low Low | 89.36 | 98.22 | 109.24 | 116.91 | 126.73 | |||||
| H42 Split Case 3:1 | 41.11 | 45.18 | 50.25 | 53.78 | 58.30 | |||||
| H42 Split Case 4:1 (or Orion) | 53.04 | 58.30 | 64.84 | 69.39 | 75.22 | |||||
| H55F w/ 3:1 | 56.00 | 61.55 | 68.46 | 73.26 | 79.42 | |||||
| H55F w/ 4:1 | 72.26 | 79.43 | 88.34 | 94.54 | 102.48 | |||||
| NV4500 w/ factory split case | 47.63 | 52.35 | 58.22 | 62.31 | 67.54 | |||||
| NV4500 w/ 3:1 Split Case | 64.87 | 71.30 | 79.30 | 84.87 | 92.00 | |||||
| NV4500 w/ 4:1 Split Case | 83.70 | 92.00 | 102.33 | 109.51 | 118.71 |
Very cool. I don't think a Google sheet will share anything but the file you choose to share. I understand your hesitation though. Could share it with someone you trust to make sure.Thanks Mark. I have a nice spreadsheet, but not sure best way to share it. Considered a google sheets document, but I am concerned that would give access to my other personal files on my google drive.
Toyota J30 Toyota H42 Toyota H55f Ratios Effective H55 w/ 4:1 split case low gears & 1.1 high NV4500 T-Case Low Gear Options 1st 2.757 1st 3.555 1st 4.843 5.33 5.61 3spd Low 2.313 2nd 1.691 2nd 2.292 2nd 2.619 2.88 3.04 4spd Low 1.959 3rd 1 3rd 1.41 3rd 1.516 1.67 1.67 Splitcase Stock 2.276 4th 1 4th 1 1.10 1.00 Splitcase 3:1 3.1 5th 0.845 0.93 0.75 Splitcase 4:1 4 AA rock box 3.44 Effective Crawl Ratio in 1st Gear NP 203 Doubler 2.0 Diff Ratio 3.73 4.1 4.56 4.88 5.29 Factory Ratio 3spd 23.79 26.15 29.08 31.12 33.73 Factory Ratio 4spd 25.98 28.55 31.76 33.99 36.84 Factory Ratio FJ60 30.18 33.17 36.90 39.48 42.80 H55F Factory Ratio 41.11 45.19 50.26 53.79 58.31 4spd Rock Box Only Low Ratio 45.61 50.14 55.77 59.68 64.69 4spd Rock Box Low Low 89.36 98.22 109.24 116.91 126.73 H42 Split Case 3:1 41.11 45.18 50.25 53.78 58.30 H42 Split Case 4:1 (or Orion) 53.04 58.30 64.84 69.39 75.22 H55F w/ 3:1 56.00 61.55 68.46 73.26 79.42 H55F w/ 4:1 72.26 79.43 88.34 94.54 102.48 NV4500 w/ factory split case 47.63 52.35 58.22 62.31 67.54 NV4500 w/ 3:1 Split Case 64.87 71.30 79.30 84.87 92.00 NV4500 w/ 4:1 Split Case 83.70 92.00 102.33 109.51 118.71
For me it was a two part upgrade. The original J30 was really clapped out. Once I took it out I could really see how bad a shape the gears and bearings were in. A lot of weird clunking and drivetrain noise is gone now that I put in a rebuild transmission. Second, and the biggest for me, was the much better gear spread as @EWheeler perfectly pointed out. Driving around in town and off road is, and will be, way better and smoother. You can keep the momentum going much better with the 4. The lower 1st of the 4speed is nice as well.This is such a cool mod, but I’m still wondering what the payoff is for going from a 3 speed to a 4 speed with the final ratio being the same. Is it just the difference in the ratios of the other gears in terms of drivability?
I agree Mark! I am thinking up pulling a H55f to go back to a H42 in one of mine.I’ve had a lot of different rigs come through the shop in the last 34 years and got to drive basically every kind of transmission ever put in a 40. I really think the gear spread of the H42 is the best of all of them. Even the H55.
H41, same as the H55f. I am debating swapping out my H41 Orion combo for a H55f split case 4:1 combo for more strength. With the 10 ud gears I would only net like 5-7% oberdrive but would have an even lower first gear and pick up a little speed in low range with 5th.Is it the 42 or th 41 have the deeper 1st gear ratio ? I am tired of the LARGE gap between 2nd & 3rd on the sm420, there should be 2 gears in that gap.
