The World's Tightest Bolt (2 Viewers)
Eastern Idaho
So, my first timing wrestling with the 1HD-T crankshaft pulley / harmonic balancer bolt. It's kicking my ass.
I tried bumping the starter; disconnect fuel cutoff solenoid, long breaker bar. Starter doesn't have the guts to break it lose.
I then proceeded to snap my SST #09330-00021 in half doing it the way the factory manual recommended.
Thoughts? Suggestions?
Any mates got a big ass 18V impact wrench?
Having done this job twice.
Once one the side of the road in a snowstorm between Revelstoke and Roger's Pass with the tools I had on board....got me home 4000km away.
Pull the rad, batteries and whatever.
You can lock in low up against a solid object, go to a big truck tire shop and get a huge torque wrench.
Put it back together with the best loctite and torque to specs.
I'm pulling everything off right now. I kind of came to the same conclusion as you.
Interesting enough, the "Gregory's" aussie manual says to jam a prybar into the inspection port to stop up your flywheel ring gears.
I've got a buddy coming over with his air tank and 1/2 impact. I think it's good for about 750ft/lb loosening.
I don’t have any direct experience with them, but I’ve heard that weighted impact sockets really help too.
On a side note.... any of you 80 series folks. I need to turn up a factory non-EGR 1HDFT crossover pipe.
I'm sure someone has ripped one off for an intercooler. I tried classifieds but haven't had much luck
:cry:
  • Back
