I understand the approach. But the problem is not in the guide pin so a larger diameter wont help you.
The problem is when you turn in the main screw (which is nessesary to get top more end fuel) the whole mechanism moves and you just cant tune it back with the afc mechnism. When you screw in the main screw far enough, you'll come to a point that the whole afc is ruled out. Besides, to tune down 1mm on the main screw you have to decrease the afc 2mm. This ratio is built in in the fulcrum lever. My new lever has different ratio's.
I should have been done other things today but was to eager to try some mods in the pump head. Took a 1hdt manual with intercooler and fast spooling turbo fitted (std rebuild pump, so no new fulcrum lever in here). I wasnt able to get afrs lower than 27 on high rpm (that s on 30psi boost from about 1800rpm) before without having loads of smoke on low end.
After making mods and do some tuning today I can get now AFRS of 1:20 all the way to the redline on full boost and only having 18 from idle! So the main screw is turned in a lot, almost on max.
Happy now, the truck already wasn't slow but is now seriously quick (0-60 in 10.5-11 secs)
