Yes, it's done by all shops when calibrating the pump. View attachment 2443018
Thats the one I was thinking of!
What did you adjust to utilize the full length of the fuel rod?Never been a fan of those LCOOL instructions. All they're doing is telling people how to add a bunch of fuel at various points with almost no understanding of how the aneroid works or what the limitations are.
I'm not going to add much to the tuning details but I wanted to show a photo of the rod that was in my 1991 1HD-T when I first looked.
It clearly shows a deep groove where the follower pin has been riding for a hell of a lot of km. In my case raising the boost didn't cause the pin to ride higher up on the flat or into the fuel cut taper because there was a black anodized aluminum ring around the rod just under the diaphragm that prevented further downward travel. The top of that worn groove is where it hit that hard stop.
Following advice from Graeme and mudgudgeon, and spending a lot of time actually learning how it all worked led me to the (more or less) same conclusions as everyone else who is tuning these things. It now travels from way, way down on the full diameter portion of the rod up to the end of the flat, which has been cut deeper than the original deepest spot. I smoothed out the transitions and put it all back together. I added with the main fuel screw until full boost full load EGTs were where I wanted them, I already had the minimum off-boost fuel I could achieve since I was out on the full diameter portion of the rod, then I tightened up the preload adjuster (star wheel) until I was happy with the level of visible smoke at mid-boost levels. This turbo doesn't spend much time at those levels so I still allow a little bit of smoke when I'm really stomping on it and is working its way up to max. It's pretty minimal and I'm very happy with how it feels right now.
@CycloSteve , how did this turn out for you? Did you keep it, tweak and tune it more or abandon it altogether? How about anyone else who used the NZ kit for the spacer to get the pin to "ride up" higher? Love it or hate it?A bit more work today. Ground the lip down on the Bosch cover, and installed the barb. Now have a bit more upwards travel with the pin.
Smoke at idle is down, but without adding a restrictor to the line, the boost comes on too quickly. Purchased two Subaru "restrictor pills", one 1mm and the other 1.2mm, and will see how those slow the buildup of boost passing to the diaphragm next week.
Great engine those WL's. They love RPM and really come alive with a tinker on the pump. Mine used to rev out past 5000rpm alsoThanks to this forum ND all u power hungry diesel heads picked up the bits of knowledge to get me started on learning how to tune my 2.5td wlt ute to have egts between 200 to peak of 700 degrees pre turbo running 30psi with all the fuel to match 5k rpm capable ND able to reach its top speed of 180kmph
The Bosch plate is still on the truck. Have not tuned it much since the initial install. In any case, it would be simple enough to just adjust it back to factory height if there was any issue.@CycloSteve , how did this turn out for you? Did you keep it, tweak and tune it more or abandon it altogether? How about anyone else who used the NZ kit for the spacer to get the pin to "ride up" higher? Love it or hate it?
Reach in with a small screw driver and push the follower pin in towards the pump, that will give the aneroid enough room to seat.
I had to remove material with a rotary tool around the diameter of the pin and also on the angle cut into the bottom in order to get the pin to seat correctly. I know the screwdriver trick pushing the follower pin in before seating the anaroid pin but this wasn’t my issue with the torfab pin. Another side note is about 2 months of having the pin installed a deep groove got worn into the pin. It’s not as hard as the material as the oem uses. Go figure.Good morning,
I'm issues installing my aneroid pin from Torfab. I can feel the fuel pin riding in the groove cut into the aneroid for installation but I have been unable to turn the aneroid pin to the ramp side. It feels as if the fuel pin is stuck in the installation groove. The new pin does seem to be a slightly tighter fit then the original aneroid pin (I have not mic'd to compare). Ideas/thoughts?
In other words your better off throwing the torfab pin in the trash and getting a new pin that is going to withstand time. I got some from jh hilux out of Australia.
No it’s just a stock profile pin but I just used it to grind my own profile on a pin that I knew wouldn’t break down over time. Some of these injection shops can get you blank pins as well so you could grind the entire profile yourself. I have gotten pins from eclipse turbo in AUS and torfab and while they look cool and have a nice profile the pin always breaks down as the metal is too soft.I noticed that groove the other day, do you have any more detail on the jh hilux one, is it the same style as torfab's?
Nah I haven’t. I’m just a garage guy and I found it quite fun to grind my own profile anyways. I’m sure you could treat the pin maybe with an outside source. I get more upset about companies making products that aren’t designed to work as they should. I know many folks have these pins and want to continue using them but why buy a 300 dollar pin just to have to pay to get it hardened so it will work like it should.Is there not processes you could treat the pin with to harden the surface the follower rides on so it won't groove? Have you looked into that at all?
I noticed the material was different, definitely not as heavy in my hand. That sucks to hear about the groove. Sounds like I just wasted some $$. So many aftermarket items are just not made well.I had to remove material with a rotary tool around the diameter of the pin and also on the angle cut into the bottom in order to get the pin to seat correctly. I know the screwdriver trick pushing the follower pin in before seating the anaroid pin but this wasn’t my issue with the torfab pin. Another side note is about 2 months of having the pin installed a deep groove got worn into the pin. It’s not as hard as the material as the oem uses. Go figure.
I communicated with JH hilux through Facebook messenger. Just a FYI as I’m not sure how responsive they may be over email.I got emails out to the companies @Magic Spool Bus mentioned, assuming one of them can supply them, I will buy a handful to practice on, and whoever else wants one to do the same.
