Ah I was wonder how to get it to move to test this, thanks.If you turn the engine over with a breaker bar the timing piston should move out, would be interesting to see its full travel to compare with Bosch.
I'm still trying to figure out how that servo thing sitting inside the timing piston actually works. I can move it freely in/out about 10mm as it is able to move independently of the main timing piston. But both springs sit on the face of it so it's a tad confusing how it all functions during operation. I've just done some small road testing and it seems the adjuster on the end cap which preloads the inner spring has a massive effect on light load timing but can't notice any change in full load timing. There's about a 1mm window where the engine will rattle its head off driving along under light load conditions vs being completely silent which is very interesting. It doesn't seem to have any effect on full load timing or timing at max rpm which I think is where the shim on the larger outer spring will affect these areas. Looking forward to carrying out more testing and to learning more about this system.Ah ok its similar to the Euro 1 300TDi and Cummins 6BT with the twin springs, i believe it allows better control over the timing advance.
Drill the shim out and install in the cap then test would be my advice.
Would there be any interest in a bespoke Boost pin for the jap pump? Made to the same material spec as a stock pin.
So glad I got this spacer kit, my car has never driven so well! I can now have my cake and eat it too. Previously I had to compromise with my static timing having to choose either having great early rpm performance and have power die off after 3500rpm or set it to have great power all the way till redline but not so great down low. Now with this spacer I can set the timing for the awesome low rpm performance and with the extra travel in the piston still have power at redline. Very happy man![]()
No I didn't end up drilling the shim and using it as I was very happy with how it went with only preload adjuster changes. Did some testing with different pe-load adjuster settings and I've found I got best results after increasing this by 4.5mm from the original position.Did you drill the shim to fit in the end? Any adjustments to your pre-load screw?
Also for those not so well versed on Toyota engines and 4wd models, what engine and 4wd have you installed it in?
I have a 80 series HZJ80 which I've converted to a 1HD-FT.
Thanks for the feedback, do you know the overall height of the screw?
Glad it's working well though!
Any updates or more info on the shim for timing advance at higher rpms?
stegs4x4.co.uk
No idea anymore sorry, the company I used to get blank ones from no longer is in business.@KiwiDingo Blank fuel pins, where I can buy them?
@hdjtrent80 @NRS91 I'm really not sure what else to say other than what I already have. The spacer kit performs exactly as it's intended by given more travel in the timing advance piston. It's allowed me to reduce my static timing to get the awesome low rpm performance I had to previously compromise on as I preferred it set for the high rpm area but now with the extra piston travel I can have optimum performance in both areas.
Most people would be the opposite to me though as most have their static timing set for low rpm performance and compromise the high rpm. So with this spacer they won't notice any change down low but their high rpm performance will change for the better with the extra timing they'll be getting extending the point at which the power continues to increase where it would normally drop off requiring you to pull another gear to keep accelerating at the same rate
Would it be possible to have this tested on a bench? Meaning if we installed this spacer that you have had great success with would we be able to see at what rpm the pump is at vs how much it is advancing over the rpm range?
Yes, it's done by all shops when calibrating the pump.Would it be possible to have this tested on a bench? Meaning if we installed this spacer that you have had great success with would we be able to see at what rpm the pump is at vs how much it is advancing over the rpm range?
So what about flow? Is there a limit we can flow this pump and injectors too? That is known I suppose. I’m trying to use Math as best I can to size a specific turbo and need to know the limits of a fuel pump modified or even not.Yes, it's done by all shops when calibrating the pump. View attachment 2443018
Never really bother to look too much into the max flow as I'm not pushing for very high HP. I've commonly heard figures as high as 160cc from local pump builders for their performance VE pumps so I guess it may be possible to get higher although I'm also guessing you'd be starting to sacrifice internal case pressure and timing control when pushing them too high.So what about flow? Is there a limit we can flow this pump and injectors too? That is known I suppose. I’m trying to use Math as best I can to size a specific turbo and need to know the limits of a fuel pump modified or even not.
