New Trollhole Dizzy Install - it wasn't all peaches and cream for me! After 3 hours of wrenching last night....finally got the new dizzy in and running.
Why 3 hours, you ask? I'm slow! Well, not really. But I'm too methodical to do anything quick when it comes to electrical stuff. Old dizzy came out rather easily, 10 minutes at most. Now is when the fun began. Installed the new dizzy, it looked to be a tooth off compared to the photos of the old location. Finally got it where I thought was right, push the rig out of the basement, and tried to fire it up. It hit, but no oil pressure, so I quickly shut it down, maybe 5 seconds at most. Pushed it back inside, and proceeded to try and reinstall it. Some how, I totally lost where the rotor was to be pointing, so I was back to square one. Thanks to the good members here on MUD and my Haynes Manual, I was able to figure out the procedure to installing a new distributer.
So all I had to do was find the BB! Jacked up the rear end/both wheels and had my son hold one tire while I turned the other...slow process! But this was my "Here's your sign moment!"....All I had to do was jack up the right rear tire and spin it, while leaving the left on the ground. So, with that process solved, I turned the flywheel to where I thought was the BB. Its location was a good bit different that where I had initially installed it. Removed the dizzy and I had to take a flat head screw driver and turned the oil sending unit to where it needed to be, and inserted the dizzy with a 'POP' at the end. Thus I knew it was seated this time. Tried to fire it up...no spark?....CRAP, in my haste, I forgot to reattach the dizzy to the coil.....Tried again, nothing except for a small back fire!!!! BUT - BUT, did see the oil pressure gauge start going up even with out it cranking, that was a positive. So I thought, where is the darn TDC line? Turned the right rear wheel slowly, and what do you know, about 90 degrees later, there is another smaller hole in my fly wheel!...Scratched my head, and thought. Maybe this is the BB? With nothing to loose, took the dizzy out again, and turned the oil sending unit to align with about 23 degrees in front of the 4th plug. Reinstalled my dizzy, it went in with a pop again, and the rotor's direction looked to be similar to a few pictures I've seen towards the #4 plug. With it all hooked back up, turned the key and it started. WOW, Me Happy! It wasn't idling smooth, so I turned the dizzy and it smoothed on out. Being the rig was indoors now, I didn't want to STANK-UP the house, so I shut it down, turned out the lights, went up stairs and got cleaned up.
Oh, for what it's worth, I never found the TDC line? I know it is to be 1" past the BB, about three tooths on the fly wheel. Couldn't find/see it?
So, after work today, I'm timing up my rig (without the vacuum line attached) and setting the idle. Then off for a test drive...if all goes well, my FJ40's DD duty will be back in service for Friday.
Old & New Dizzy's:
