77 fj40 metal clutch tube
Stainless flex hose $30 clutch
after market brake line $60 each #35,36
My new clutch master/slave came with the SS flex hose. Seems to work fine. The rubber part was OEM, I think the steel section is around here some where.
3/16 Nicopp for easy bending and two brake line fittings (10mm) from the junkyard or spare broken lines - then flare and install.
Or find someone parting out a truck and take the line - very low desirability when parting out for those.
3/16 ni-copp, you might be able to use your old fittings or buy a section long enuff at the a/p store. Always double flare the ends.
