1HD-FTE turbo has a newer, smaller turbine wheel and housing, and larger compressor wheel than ct26.
Smaller turbine will bring boost on at lower RPM, larger compressor wheel will pump a greater amount of air, so more air available at the same boost level.
Upgrading the compressor wheel only will get you an improvement, but upgrading the turbine as well also has gains, the two together even better.
to use the 1HD-FTE turbine, you need to use the ct20b central housing.
