1hdt housing is the smallest. Somewhere around 0.40 A/R
If I'm going the Supra Hybrid way - what can I expect from the turbo if I go with a Melett CHRA ( Supra 7mgte ) and a Toyota housing and the smaller 7cm turbinehousing ?
Where will my boost start ? Or is that hard to tell ?
It's a little hard to tell, there's a few variables such as exhaust, air intake, tuning. More fuel will help it boost earlier, but there's limits.
My supra hybrid with stock 1HD-T rear housing (8cm), 7MGTE compressor, on a 1HD-T produced useful boost around 17-1800rpm (10 psi, and 15 psi by about 2000rpm). It made quite a bit more low end torque than stock turbo, and it was making strong power right up to around 3500+rpm. The turbo was quieter across the rev range.
My 1HD-FTE turbo (6cm turbine housing, smaller, more modern turbine, same size compressor as 7MGTE) on my 1HZ is producing strong boost from around 12-1300rpm.
Same size engines, both fueled up a bit, but not over the top. 1HZ has higher compression, so has better low end torque before the turbo spools.
12HT are a torquey beast, but 4.0 litre vs 4.2.
With a 7cm turbine housing, and Supra compressor, you'll have a pretty decent upgrade over stock. Earlier boost with the 7cm housing, more torque due to higher airflow, better response at all rpm, more mid range power. The top end power may suffer a little as the smaller turbine housing will be restrictive at high rpm
Well worth while IMO. Good bang for your buck.
Not as impressive as the gturbo types, but nothing to be sneezed at either.
There is no reason to go supra hybrid. Just get a 1HD-FTE turbo and make it fit. It's got a supra size compressor and a better turbine.
The Mamba I purchased uses a 1HDT housing and bolts to the manifold and exhaust.That was my conclusion. I have a 1HD-T/7MGTE hybrid sitting in the shed that I won't use.
I think mamba do a 1HD-FTE replacement if you're thinking of going mamba.
It won't quite be bolt in, but a fairly simple adaptation.
better effiency ( less fuel ? )
Better turbo efficiency, (not fuel efficiency)
Been looking on Holset turbos lately, how well would a 12H-T and HX35 Super come together?
Main benefit over old CT26 would probably be light years more modern design, faster spooling and greater efficiency.
Fitting a Holset turbo would not be nowhere close to bolt-on, but a lot cheaper option than G-Turbo and others.
PLUS, you can find used units for cheap from time to time.
Compressor: 54/77mm
Turbine: 65/55mm
Turbine housing: Single entry T3 8cm
So is a HDFTE Turbo more efficien, modern ?
Even with 8cm exh. housing? Turbine is just a tad bigger than stock CT26.Terrible. HX35 is too big for all but 3000rpm and up. Standard exhaust housing on those is 12cm. Going any smaller just drives them into surge at lower rpm.
HX30 Super (46mm compressor intake, 6cm exhaust housing) is the best match and a very good turbo. But it's a more active turbo than most are fitting on Toyota 6's. Best use is low rpm sloggers like Isuzu 4BD1T and Cummins 4BT. It would however be a very good high-altitude turbo on a Toyota 6 cyl.
What size compressors G-Turbo uses on his high output turbos
HX30 looks to be about the same as 7M Ct26 but with smaller exhaust housing, i would imagine that to be a problem on highway?
The reason i'm asking i've heard good results on hx35/12 1HD-T combo. I know 1HD-T is way different from 12H-T, but still.
