Replacing that weak ass sunshell is a lot of work.Minimal (and nearly free) mods can cure this. The 4l60 gets a lot of unnecessary hate. But yeah, the 80 is more stout.
Yeah, and maybe it will blow tomorrow, but miraculously mine has held fine to 180k miles with 60k of it in a fully built 80 on 37s that is driven by a maniac daily and wheeled. Cheap easy mods.Replacing that weak ass sunshell is a lot of work.
Swapping over to an 4l80e after your build is done with a 4l60e isn't a quick or easy task yes they bolt to the engine and transfer case but are different lengths. Adapter forthe 4l80e doesn't have a sensor in it like the 4l60 its a different adapter between the two model transmission's.A gm transmission is so easy to replace I consider any worry of a 4l60e not lasting forever as a almost non issue. You can always upgrade to a 4l80e easily if needed or buy a beefed up 4l60e.
Yep. Just start with an 80 IMO.Swapping over to an 4l80e after your build is done with a 4l60e isn't a quick or easy task yes they bolt to the engine and transfer case but are different lengths. Adapter forthe 4l80e doesn't have a sensor in it like the 4l60 its a different adapter between the two model transmission's.
If you’re capable of (cleanly) LS swapping an 80series alone in your home garage I’d consider it both.Swapping over to an 4l80e after your build is done with a 4l60e isn't a quick or easy task yes they bolt to the engine and transfer case but are different lengths. Adapter forthe 4l80e doesn't have a sensor in it like the 4l60 its a different adapter between the two model transmission's.
Not sure what you mean?If you’re capable of (cleanly) LS swapping an 80series alone in your home garage I’d consider it both.
Anyways... OP, let’s see some pulls!
We'll have some once I get my new tune done. The trans shift points need to be adjusted. We did a 250 mile highway trip today and it was awesome!If you’re capable of (cleanly) LS swapping an 80series alone in your home garage I’d consider it both.
I was aware the 4l80e was longer. I also know the wiring is slightly different. I didn't know the adapter was different.Swapping over to an 4l80e after your build is done with a 4l60e isn't a quick or easy task yes they bolt to the engine and transfer case but are different lengths. Adapter forthe 4l80e doesn't have a sensor in it like the 4l60 its a different adapter between the two model transmission's.
So you can use the same 4l60e adapter but just need to add the tone ring?The real problem is the reluctor ring on the out out shaft. On 4l80e 4x4 vehicles the output reading was in the transfer case. On 2wd vehicles, the reluctor ring was buried in the transmission on the output shaft. Same parts, just one is missing the $35 tone ring. Pair that with most people buying a complete pull out engine and tranny (a lot of the engines, at least where i live, are 4x4). I did a 4l80e, not sure if many other people have....and i tore the tranny down and rebuilt myself. Took a weekend, i could probably do in a saturday now. A shop could probably do 2 hours just to put the tone ring on. Of all the money, if one wants a 4l80e, they should just do it. It's a couple hundred at most for the tone ring. Or, if you diy, you can get all new clutches, seals, consumables etc For the same price. Bust honestly, if I'm putting a new tranny in mine, might as well go to 6 speed or greater.
Probably just comes down to availability. 4L60s are everywhere. 4L80s are everywhere. 4L65s came in a much narrower range of applications.4L65E GM fixed the issues with the 4l60E Improved sun shield, 5 planetary gears rather than 4 along with other up grades
Odd that it seems to never get mentioned
I don't know that off the top of my head. My gut feeling is no. I also disagree that it's an easy change on an already completed swap. The output shafts probably are different as well.So you can use the same 4l60e adapter but just need to add the tone ring?
Most guys that want swaps want to go with used engine and used transmission to keep the price down for them. Thats why the 4l60 is more than likely to be used in a swap and the 4l80e gets used less because everyone is stuck on the 4l60 having a lower first gear. So they go with the weaker transmission because of that lol.That makes sense. I guess it is because when I look for a used motor I do not look for a motor and trans together as a package. Either way the trans would be rebuilt so I just go straight to a remanufactured trans, often a Monster trans. I've had good luck with them over the years. I also use the 4L65E with the LS3 in a Connect & Cruise package (when they are available). It is a proven combo that pulls a Land Cruiser around with no problems. There are also two adapters available that actually work!
One big item, no matter what trans you are using is proper cooling. I use a trans cooler in the radiator and then a stand alone cooler then back to the trans.
Why not just use a ZF 6 speed manual? Is that a viable option?Most guys that want swaps want to go with used engine and used transmission to keep the price down for them. Thats why the 4l60 is more than likely to be used in a swap and the 4l80e gets used less because everyone is stuck on the 4l60 having a lower first gear. So they go with the weaker transmission because of that lol.
I have a 80 here at my shop for a customer he wanted a 5speed manual transmission thats the easy part finding all the clutch pedal stuff and the interior bita is the hard partWhy not just use a ZF 6 speed manual? Is that a viable option?
