Storage Solutions
Here is another one from this thread
fuelgeddes said:
Low Cost , Light weight storage box.
This is in no way at the same level as some of the craftsmanship that I have seen here. This project makes me even more envious of some of the skills and thought that I see here on Mud. My hats off to those who can think it up and make it happen. (keep doing it)
My goal was too create a light weight yet strong storage solution for the rear ½ of the LC. When I say strong I mean strong enough for general camping equipment / with a distributed weight range. (my cooler will sit on the floor next to the box) The primary objective was to build the box to be easily removable so it needed to be light in weight and easily bolted or strapped down. The box needed a hatch On top upfront so it can be accessed with the tail gate closed.
1. I wanted to still use one of the third row seats.
2. It needed to be light weight enough for easy remove and add back.
3. It must securely bolt / strap to the floor
4. It must not make a lot of noise when off road. (no rattling)
5. Second row seats must be able to fold forwards
Dimensions of Box: 20 inches wide by 41 inches length.
The Box height is 6 1/2 inches.
Wood: 8 foot 2 by 6 pine.
8 foot 2 X 4 pine (for draw sides)
2 Ply board ¾ 24 by 24 squares
2 Ply Board 3.4 24 by 4 feet
Other Misc.
2 rolls of rubber drawer liner
2 small hinges
1 bottle of wood glue
1 forgotten candle for wax
1 sheet sand paper
Tools:
circular saw
Drill
Screw driver
Brad Nail Gun
Staple Gun
Total Cost : less than 50 dollars
Total Hours to build : 9 hours +
Results of the build:
Well the choice to go light weight was good one but posed some problems. This box is not made to take several people standing in the middle on it, but it seems to have a good distributed weight range towards the edges. This will more than meet the need for carrying camping equipment and jumper cables, trailer hitch, lights, ropes, fire extinguisher, etc.. But by using thinner wood you have to take into consideration of where you can place screws and hardware. So I am staying away from any fancy hardware right now and going with rope pulls for handles. I think this will make it easier to meet the no raddled requirement. I am also going with a wax treatment for the slide of the drawer. The only thing I have done a little different than some of the other folks is that I placed two bottom slides on the top of the box to make getting things from the back easier when the tail gate is open. I don’t have to climb in there to get things. The draw can open towards the front from the rear area if the second row seats are folded forward. The biggest is that it is really easy to pick up and move. One major thing is to place the wood gain across the opening not with it for added strength. Also PINE is a light weight wood which needs some protection once built. I went with a shellac stain so I could see the wood gain. Also this box does not weigh enough to cause the truck to lean even when fully loaded.
GO Here to see more pictures > http://mytlc.blogspot.com/
Attached is one picture of my storage solution. If you want more detail, here is my write up on the storage solution I pulled together; https://forum.ih8mud.com/showthread.php?t=111868.
Here is a unique idea from this thread
All weekends this summer I have been travelling with my friends, mostly with 3 passengers in the 80. The cargo area in the back is just too small.....
So I had an idea to make more space. And got a friend of mine to make this box for me.
Then I got me some powertools and made a hole.
I had already removed all the spare tire mechanism from the back, it was completly usless from rust anyhow. So I had alot of unused space down there.
And one pic in the end of the finished product.
Next on the plan is to buy some plywood and make a plate to fit on the floor and make a lid.
Now I have penty more room for my toolbox, spare parts and stuff I never use :) the last time I had to use my toolbox was to help a friend with his JEEP...
Build thread here
Before shot - old drawers
attachment.php
After shot - new drawers
attachment.php
Nice Cragger! I'll give you $590 for them :)
Nice Erwin, but did you fix the heat shield on your cat yet?
Here's a pic of my storage for the log.
About 40lbs altogether with a height of about 9 inches. Wood, a little steel, and a tiny bit of aluminum covered with some sturdy material and texture paint.
I should have said a 1650 case, not a 650. If you look around you can find one without any foam in to for under $200, just google Pelican 1650. Here is a link that shows all the different models: Pelican Cases at Pelican-Cases.com
I will try to remember to get a pic of it in the back of the 80 tomorrow to give an idea of size.
I get all my Pelican stuff from Ralph's Pelican Cases. They seem to have lower prices than anywhere else online. The shipping is really inexpensive as well. They have that 1650 Case with No Foam for $173. Seems like a good deal.
My Storage Solution - AKA Lessons Learned
I finally finished my cargo solution. There really isn't anything ground breaking about them, especially since I blatantly stole most of the ideas from you nice folks. But more than the drawers themselves, I figured I would post things I learned while making them that might help people plan their systems. A self critique, if you will, but there are some things that people may want to consider first when planning these projects.
Since drawers in an FJ80 has been done a thousand times, I strongly considered ordering a set from Warfield Offroad. In hindsight, that still may have been the best route given his very fair pricing and good reviews.
Here's what I wanted out of my system (in no particular order):
1) Was relatively easy to remove and return to stock (mostly accomplished)
2) It wouldn't look terrible. (accomplished, IMHO)
3) Could be used as a sleeping platform (accomplished)
4) Had tie downs for storage (accomplished)
5) Was secure and kept the cargo secure (accomplished)
6) Had hatches for easier access (mostly accomplished)
7) Had covert storage (accomplished - until I reveal it here :D)
1) Easy to Remove
I think I mostly hit this one, but this is also where I learned a lot (aka screwed up). Based upon others, I went with 1/2 inch Birch Plywood and I am really glad I did. It is plenty strong for cargo and sleeping. There really isn't any need to go with 3/4 inch unless your hauling A LOT of weight or covering much larger openings (i.e. one piece platform in back of a pickup).
I also liked the Warfield version how it used metal framing and a two piece system.
This makes it easier to remove and allows me the option to replace on of the third row seats. I went in thinking it also saves a significant amount of weight. In hindsight, I doubt it saves a whole lot of weight over a complete plywood box, but I think the metal substructure does create a better way to secure it and attach the cargo tie downs above:
Drawers - Here's where I learned the most. Going in, I was unsure whether I wanted drawers. They add weight and add a significant amount of time and cost to the project. But they are convenient for getting stuff out and they certainly add a more finished look to the project. So in the end, I went with drawers, but I'm still not sure it was the best idea. I will try them out for awhile, and may actually remove them at some point.
Some things to consider about drawers (In addition to weight, cost and time), is that they reduce your usable storage too. The picture below doesn't illustrate it too well, but you lose precious inches with drawers. In addition, you can't pack stuff in tightly since it needs to slide freely to open and close.
My other screw up, I mean lesson, was in the slides. I used the 200 lb KV slides from Lee Valley that most do. They are plenty strong and seem to be very good quality. But you know what??? They don't separate!!:oops: Once built, your drawers are in for the long haul! I don't know, maybe none of the heavy duty slides separate, but this was significant to me. First, it makes the removal of a carrier that much more difficult. Secondly, it's that much more of a pain to build the darn things.
On the plus side, I'm glad I went with the $40, 200 lb slides (For most people I really think the $100, 500 lb slides are overkill). In the end, they still attach with dinky little 1/2 inch screws (although I used a couple through bolts with nuts on each one):
I really think the best set up is just a platform with large tupperware type pullout containers. The problem there is finding the right size containers (which is why I ended up with drawers). I also like the drawers that just slide on cutting board material which maximizes space and is simple and cheap. Just some things to consider.
2) Looks
I 'll let you guys be the judge, but I'm pretty happy with it. It's not perfectly symmetrical, but the $8 Walmart carpet matches pretty well. I also like how the entire surface is now flat without the fender bumps in the way. If nothing else, my hockey sticks fit perfectly flat now.
3) Sleeping Platform, 4) Tie Downs, and 5) Cargo Security
My big concern here was having a very flat surface. This meant no piano hinges on the latches and flush mount tie downs. I actually ended up not using my flush mount tie downs because I liked the low profile ones better and they are positioned at the outer edges. But if they become bothersome, I may switch back to the recessed ones. They are bolted through to the metal frame. The metal frame is bolted directly into where the 3rd row seats attach. In other words, in a rollover or other serious accident, it's not going anywhere and I'm not worried about heavy tools flying around and hitting my family.
6) Hatches
This was another "learning" area.:) I really liked the idea of hatches to quickly retrieve stuff. They also provide access if you can't get the drawers open for some reason. The reality is that it is pretty darn tough to get anything out through the hatches. Perhaps I should have just made them huge? But I would be hard pressed to try to pull my tool bags out through that hatch. The other issue is securing the hatch. A hatch is no good, IMHO, if it can fly open in an accident and send a heavy tool flying at your head. Although I think piano hinges are probably the best solution, I had to work around that since I didn't want hinges in the middle of my sleeping platform. I had to add supports (1x2 wood) to support them from underneath. This further interferes with drawer space. (you can see that in the unfinished drawer pic above).
7) Covert Storage
You may question the sensibility of posting my hidden compartments here, but I'm really not too worried about you guys stealing my stuff.:) The beauty of these platforms is there is all sorts of places for compartments and false bottoms. Why, you ask? Because people love breaking into stuff at trailheads. So let's say you've parked at a trailhead or your remote campsite and you are going to take a hike or swim in the lake. It's not practical to take your wallet, passport, firearm, Ipod, whatever. But locking it in the car isn't all that secure either. I'd rather take my chances with a good hiding spot than an easily defeated lock. Even if they steal the car, my guess is they will pass over good hiding spots and I will get my stuff when the car is recovered (and hopefully not torched). I went pretty simple and used a screw as a hing and vecro for a latch:
There's a surprising amount of space in the void by the fenders and it is a spot easily missed - especially with a quart or two of oil in front of the door.
Well done marc311! very thought out.
After building mine I started a list of the changes I would make for the next one, it's getting longer and longer.
