03-22-07, 10:07 AM
T-Case skid plate build (pic's)
So, I'm getting ready for my first trip to Moab Utah for Cruise Moab in a little over a month and figured I needed to beef up my OEM t-case skid plate. I looked at some of the different skid plates out there and decided not to go with the large but very beefy iron pig type due to the type of wheeling I do.
So this is what I did. I purchased a 13" x 22” x ¼” thick piece of plate steel from my local steel yard. I then marked it to the specs you see below and had them cut the plate to match.
Once I got home I struggled to figure out how to bend my 45 degree angles in this thick stuff without a very big brake press. After much consideration I used a very thin cutting wheel on my angle grinder and ran a line across the steel where I wanted the individual bends (about halfway through the 1/4” plate. This allowed me to bend the plate with a BFH clamped to a block of heavy steel as a straight edge. In the diagram below you will see where I placed my bends. Note: I placed my outer most 45 bends on the front and back of the skid plate more than 1” in. You can put them as far in or out as you feel comfortable with. Once I got all of my bends where I wanted them and test fitted them under the truck I then welded shut the gaps of where I had cut the steel with the cutting wheel.
Next steps will be to drill the three mounting holes and to build a bracket that will attach to the frame rail supporting the rear most part of the skid plate. I also need to drill a large hole via a hole saw so I can drain my t-case without having to remove the skid plate.
Zane Zwerenz
2000 UZJ100: 285/75/16 BFG's , OME Torsion Bars, OME 866, Slee Diff Drop Kit, ARB Sahara Bar, Slee Rear Bumper, Hella 4000's,Safari Snorkel, Custom Built Sliders, Custom Built Rear Tire Carrier, Modified Mombassa RTT
1997 FZJ80 (SOLD): Custom Built Sliders, Custom Built T-Case Skid Plate, Custom Built OEM Bumper Tire Carrier, Rear Storage Solution, Modified Mombassa RTT, 851/860 OME, 285/75/16 TOYO Open Country MT's,
www.tornadoalleycruisers.com
03-22-07, 10:09 AM
Attached are some pictures of how it turned out. For reference the first picture is the "TOP" and the second two are the "BOTTOM" of the skid plate.
Zane Zwerenz
03-22-07, 10:25 AM
looking good. Should work well. Post more as you progress.
03-22-07, 11:08 AM
Awesome work...Wish I had the skills and time to do that.
Alas, I took the easy way and just bought the Slee skidplate so now all I have to do is find the time to install it
'97 LX450 aka "The Whale" with a winch called Damien
'97 FZJ80 40th AE, Antique Sage, #267
'74 FJ40, 2F, SM420, 4" Lift, ARB locked front and rear, 33" MTRs
'76 FJ40, 2F, 4-speed, 4" Lift, 33" BFG ATs (SOLD)
03-22-07, 11:22 AM
Cool - I like how you did the bends with the cutting wheel, steel block, BFH and welding the gaps shut - Going to use your bend technique to fab one up once I get some spare time
95 FZJ80-Locked-OME 850's w 1" spacers OME 863's-ARB-KAYMAR-Sliders-BFG 315/75/16 AT KO'S-Dual Batteries-Onboard Air...
03-22-07, 01:32 PM
That took me like 15 minutes, and I'm a complete idiot when it comes to putting stuff together.
1994 FZJ80. Stock as hell. Lockers. Slee skid plate. Better speakers + CD player, no flares. Lame.
03-22-07, 02:16 PM
Originally Posted by zjz4476
Once I got home I struggled to figure out how to bend my 45 degree angles in this thick stuff without a very big brake press. After much consideration I used a very thin cutting wheel on my angle grinder and ran a line across the steel where I wanted the individual bends (about halfway through the 1/4” plate...
I use a circular saw with a metal cutting abrasive blade, set the depth and rip! The blade wears and you have to readjust the depth often, but works great.
Copper State Cruisers #007
03-22-07, 02:25 PM
Not a bad idea, but with a cutting wheel on an angle grinder you dont ever have to adjust the depth.
Zane Zwerenz
03-22-07, 03:05 PM
When using a hand grinder, I find that I have to constantly, manually adjust the depth of cut!
03-22-07, 03:20 PM
#10 (permalink)
Touché
Zane Zwerenz
03-23-07, 02:52 PM
#11 (permalink)
if you are in a big hurry to bend steel corrigate (sp) it by cutting most of the line with a torch/plasma cutter and just leave a few joining pieces of steel to hold stuff together. then bend away. by the time you weld it up the line is stronger than the orriginal mild steel anyway
http://forum.ih8mud.com/showthread.p...highlight=skid
97lx450
1 tons and 42's
4" slee coils, sliders, bumpers, 3" exhaust, custom turbo, HG pm/Valve job/seals, sweet custom skid plate, Sleeoffroad parts, Buys oe parts from Cruiser Dan
my build
http://forum.ih8mud.com/hardcore-cor...j80-build.html
98 100 series. rear locker.
2008 6.7L dodge 2500 quad cab
ezgo electric golf cart crawler build pend....
2002 porsche C4S
03-26-07, 09:10 AM
#12 (permalink)
OK, I finished this project up over the weekend. Please see attached pictures of finalized t-case skid plate installed. I still need to drill a hole with a hole saw for my drain, but will need to remove it and take it to a friends house who has a drill press. Other than that its done. Fairly easy mod with the right tools and total cost to build was about $30.00.
Zane Zwerenz
03-26-07, 09:12 AM
#13 (permalink)
I wanted to also show you how I built the rear bracket to support the back of the skid plate.
let me know if you have any questions.
Zane
Zane Zwerenz
03-26-07, 09:56 AM
#14 (permalink)
You want to do what...?
consider using Allen buttonhead bolts for babysmooth glidin' ?
 : '97: 90K, 3xlock, 285 MT/Rs on steelies, Hanna sliders, 851+1.5"/863/N73/N74E/SD24, ARB bull with M12, Kaymar with duals, Kaymar rack, Slee TC skid, 2m/440, more stuff, loose nut behind the wheel!). Custom HD roo bar for sale!
 : '03: 115K
DDs: Accord, Prius
 : souped-up DR650
03-26-07, 10:07 AM
#15 (permalink)
Nice work, now lets go product test it in Moab!!!!
03-26-07, 10:09 AM
#16 (permalink)
Zane,
Nice work!
Since you're in the fab state of mind I'm gonna PM you an idea and see if you're interested.
Button heads are nice but once they have been ground over rocks many times you'll never get an allen bit in there. The standard hardware at least gives you something to grab with Vice Grip.
1994 80 - Some stuff
1988 4runner - cute little brown thing affectionately known as "sh*t stain"
Those who can, do; those who can't, criticize - Unknown
Strive for perfection in everything.
Take the best that exists and make it better.
If it doesn't exist, create it.
Accept nothing nearly right or good enough.
Sir Henry Royce
Co-founder, Rolls Royce
