LAMBCRUSHER
pivot anchor needs to be well behind the seat back to do anything good for you in an accident....front or rear....
I would be inclined to fab a support and fastener aft of the C pillar in the roof rail. I really think the shoulder belt needs to be secured BEHIND the back of the shoulder or else it is pointless. no sense if going to extra work for protection that may only add to injury- realize I'm waaaay out on a limb for that statement.Best fab an interior cage and weld anchors where ever they need to be
Bump on this question - is there a left and right side retractor?
Here is what I have, all three part numbers end in "R" and it looks like the shoulder mounts are all for the passenger side.
View attachment 411854View attachment 411855View attachment 411856
Going back to this question - can anyone eye their original retractable belts and tell me if they have a L and a R? Are the retractors all on the same side, regardless of what side of the Cruiser it is mounted on?
I have these 3, and all the retractors are on the same side. Wondering if these can serve in either side of the Pig?
Not getting too many answers on that question - hoping this question fares a little bit better:
If you have the factory retractable 3-point belts in your Piggy, does the metal part you buckle face in (into the interior) or face out (out towards the window) when the belts aren't buckled?
TIA!
I am pretty sure I referenced my build thread with what I did. I don't really want to go back through 5 pages at this point.resurrecting an old thread, as I am looking to add 3 point shoulder seat belts to the front bench seat in my 73 FJ55. Wanted to see if ahyone here has done the upgrade recently? Thx!
Factory bolts I believe are 11mm 1.25 pitch, not easy to find a good variety of hardware in this size.
7/16” – 20 is virtually the same and much easier to find. Just convert them over unless you have a specific reason to keep everything metric.
1.25 pitch = 0.04921 pitch in inches
20 Thread Per Inch = 0.05000 pitch in inches
11mm = .4331”
7/16” = .4375”
Get some 12mm x 1.25 and you'll be good.
When in doubt if I’m going to modify safety equipment from factory on a factory vehicle I’ll look at the guide lines of FIA or SFI.
SFI says Shoulder Belt Angle: 0 to -20° (-10° optimum) from horizontal
Seat Belts | SFI Foundation
I thought SFI said a seat belt anchor point backing plate should be fashioned out of a piece of 11-gauge steel with an area of about 6 square inches minimum but I can’t quickly find that info to post as fact so take it as speculation.
LOVE IT! I just need to find/sorce a set of these plates to weld into my pig. Anyone make these or have a set they want to sell me?I believe several have installed three points. Here's what I did.
Backing nut for the third point.
Welded it on the B pillar where I wanted it and had to pull the nut up from the bottom with a wire.
Right about here on the model. Don't mind the ugly mug, he's just a hired hand on the farm.
