Or you could do an internal cage and throw in some 5 point seat belts!
Thats my plan for next summer. The headliner is rotting out of my junk and I need to do something up there to keep the roof shapely. Thinking a cage with some crescent moon looking chunks of 1/4" maybe to help be roof support/family protection. The seatbelt situation is abysmal and rather than messing around with trying to fit potentially $$$ junkyard seats with integrated belts (which really limits your options anyway) may as well really beef up personal protection.
The question is, as will all internal cages, how do you install it? Weld it all? Weld some and have bolt in chunks? I've also been thinking about the A-pillar bars, I think I'll have to move my headlight knob because that looks like right where that thing wants to come down...
Has anyone else on here done an internal cage on a full-figured pig? I'm not interested in looking at a near buggy pig (puggy?) with only the front clip remaining...
So on this same topic, I got some shoulder belts out of my 76' parts pig... I wanted to use them in my 73' 55 but the retractor box mounts to the lower B pillar on the 76'... my 73' does not have the mounting hole. Anyone seen/done something to make these work?
I am using extensions and FJ-60 belts that are too short, they won't fit anyone with much of a waste....
bump, anyone?
I think that you could probably find a 60 that has retractable 3 point belts and then install them throughout the whole rig. At least that is what I am shooting for.
good point on the 60/80 series belts! that would be a cool option and keep it toyota. Yes, that rear mount you circled is the one I was talking about. Anyone used 60 or 80 series belts on a 55 out there??
Noah
I thought about this too - it sounds like the 60 belts don't run out long enough? Wayne, do you run with the seat all the way back?
I am also looking at the retractable 3 point kits that CCOT sells and I think they might work for the 55. I have them in my fj40, so will probably pull one side and see if they work, that is, when I get to that point in the rebuild. I am WAY far away from that now....
noah
Two options that you can consider for stock look
Retractable Seat Belts - not a bad fit, although they don't provide metric hardware - you'll need to fab a spacer for attachment at the "B" pillar.
Homepage can restore you originals, if the buckles are inspected and found to be OK.
Never have seen anything other than lap belts in the back - maybe someone else has done a retrofit.
Harry
no problem to mount them on the 69......... just slip in some 10M steel rivnuts with a backing plate to the bottom of the "B" pillar........HA!, the original hex head bolts that I got with this set are a bastard size 11M; fine thread at that
.......no such an animal exists in rivnuts
..........would like to go with original hex head bolts
, they are boxed now and ready to send to Ssnake-Oyl in the morning.......
