Sequoia vs 100 series
Sequoia is part time 4WD.
And no fold down tailgate, which is the real reason to have a cruiser.
So it already comes with the part-time upgrade?
It’s crappier. ADD system with no option for manual hubs, so even in 2wd the front CVs are still spinning full-time, just no power to the front driveshaft. Thus, it doesn’t save the front end from wear.
A Sequoia is by far the best bang for your buck in the Toyota 4x4 world. It’s a damn lot of truck for the money.
deleted
Isn't the land cruiser engine, suspension linkage, transmission, brake calipers, etc all just parts bin stuff? I mean, it seems that the engine and trans are the core of the platform and those aren't special or "overbuilt" beyond the tundra/4runner/sequoia applications?
Also, plastic heater tees, I dont' think the sequoia has that problem
Very few major components on Sequoia are shared with LC/LX. Yeah 2UZFE long block, Shell of the A750 Trans ( but all FJ's, later model 4runners and others equipped with it too) but gearing different, transfer case different, brake system different: calipers, ABS, booster pump, accumulator all unique to 100 series; and the overall build specification for LC/LX built to a different standard as was mentioned earlier.
As indicated in my signature, my household owns both a 1st-gen Sequoia (2003) and an LC100 (2000). The Sequoia is actually our second; our first was a 2006 that suffered a catastrophic engine failure. To the best of mine (and my mechanic's) knowledge, a P/O had put stop leak in the coolant system, which clogged one of the water passages in the D/S head and resulted in a major head crack. Regardless of that, which I don't feel represents the quality of the Sequoia as a whole...
The 1st-gen Sequoia is a very nice vehicle, but it is completely different than the LC:
Size: It is a MUCH larger vehicle than the Cruiser, which is IMO it's biggest benefit. It was introduced to compete directly the 1st-gen Ford Expedition, and is within fractions of inch identical in terms of its measurements. The clear width of the rear cargo area between the rear wheel wells is over 49 inches, so the Sequoia will swallow sheets of plywood inside. There is probably more than twice the depth between the 3rd row and hatch as well. I can put my 40qt Orca cooler behind the 3rd row in my Sequoia, not so in my Cruiser.
Chassis/Running Gear: This is all based on the Tundra, which is in turn based on the Tacoma/T100. It's good, but not nearly as strong and beefy as the Cruiser. Compare pics of lower control arm, CV axles, and tie rod ends to see how much heavier everything on the Cruiser is. They both use the 4.7L 2UZ-FE of course, but technically they are different engines, tuned slightly differently. The Sequoia engine is built in Alabama using mostly domestic-made parts. As I understand it, while tune up items and most sensor are the same, a lot of the parts are not directly interchangeable due to the location of brackets, etc. It's funny because, between the two, I think my Sequoia is zippier off the line, but the LC pulls harder at higher RPMs. Of course, my Sequoia is electric throttle and my LC is cable throttle, so that may have something to do with it.
On 4WD versions, the transfer case has an electronic locking differential (open on the early versions, Torsen on the later versions, like the LC) and an Automatic Differential Disconnect on the front differential. This is an vacuum-actuated sliding disconnector which decouples the D/S CV shafts from the differential (not the front drive shaft, as some sources say). The front diff always receives power from the transfer case (like the LC), but the front wheels are not driven when the D/S CV is decoupled. This allows a "false" 2WD mode, although I don't think there is really any MPG benefit like on a true part-time 4WD. The 2nd- and 3rd-gen 4Runner Limited used this, as did the GX470. It's a decent system, though the diff is not as strong as the LC diff. As JunkCrzr mentioned, the front wheel bearings are sealed, non-adjustable types, although they don't seem to fail very often.
Body/Build Quality: The Sequoia is noticeably noisier, and compares to other domestic Toyotas, as opposed to Japan-built Toyotas. Every 1st-gen Sequoia I've seen has rust at the front hem-flange weld of the rear wheel arch, and the panel directly adjacent. This is covered by the rear door, so you don't see it when the doors are closed. I consider it to be a fault in the body design/rustproofing. It's interesting to note that, despite its significantly larger size, the Sequoia weighs 900 pounds LESS than the LC100! So that should tell you something!
Interior Features: The Sequoia is very much in line with other domestic SUVs from the era. It is full featured, but without some of the "luxury features" of the LC (although by 2006/2007, the Sequoia Limited was fully inline with the LC and most Lexus models for luxury features). The early, pre-facelift Sequoias (which my 2003 is) share a dash and a lot of interior bits with the Tundra. The dash is hard plastic and the whole impression is more utilitarian. In 2005, they introduced a soft-touch dash and some other niceties that were shared with the 4-door Tundra Limited. My Sequoia is cloth interior, which I wish my LC was!
Overall, the Sequoia is an always was targeted to the soccer-mom, people-hauling crowd. For that, I think it is excellent. It is noticeably higher quality than any Expedition/Suburban/Tahoe/Yukon from that era. Plus, it is a Toyota, so I think it's off-road 4WD chops are better than anything contemporary in its class. But, it is not an LC, which is Toyota's global flagship vehicle, designed for a 25-year service life in the third-world, able to be maintained with basic tools. That said, our Sequoia is our go-to road-tripping vehicle because of its size. With four kids, you can't have enough space.
He wasn't even try that hard on this one. No points for @nukegoat , but minus 5 for everyone that took the bait.
It's the subtlety that's most impressive.
You get to keep your 5 points because this was a great write up.
Yeah, it's super fun to troll the forum and get people to give you earnest answers just for grins.
I know people think this is trolling but maybe people who just need a cheap durable wheeler without brake failure issues would appreciate digging into the differences in drivetrain and durability
I know people think this is trolling but maybe for people who just need a cheap durable wheeler without brake failure issues would appreciate digging into the differences in drivetrain and durability
It is very odd to me that the 01 and up 4Runners, Tacos, LCs/LXs, and Tundras all had the same electronic ABS/Booster assembly with accumulator setup, but the Sequoia retained a normal mechanical booster.
Oh so selfless of you.
Do a "what lift kit should I get" next.
