Rosen aircraft sunvisor to replace sagging visor? (3 Viewers)
Do any of you know if the 7S10075-03 part number is still the number I would use to order these?
Should be. But mine were the short ones. If you want the longer its a different part number. I would just call or email them.
image-2618347567-jpg.724351
Definitely two sizes...at the time. I opted for the shorter ones.
Ryan, the standard visor they are selling have the shorter lens... they do not sell the longer lenses mounted on the arms ...they only sell them as replacement lens.. I'd email him back
From my earlier post:
Rosen update... the Icon visor measures 15.1 they have another lens thats 16.71 for an additional $50.00 .. I told Dan to ship the extra lens
Thank you guys, I just got off the phone with Dan and he honored the group buy price!!
"Attached are the drawings for the lenses that come on the system you are ordering (7S10011) as well as two possible alternate lenses. My only concern is not knowing how close the mounting assembly will be to the side of the vehicle as the longer lenses might extend too far to the right and left of the mounting location. The distance from the first hole on the 11 lens is 3.845” compared with 4.81” and 4.64” on the other 2 sizes. If this larger dimension is not going to cause any interference with the movement of the lens to the side window, then either of those would work as well (your cost: $50.00/ pair of extra lenses)."
There's nothing attached? The mounting assembly bolts into the factory visor holes...you will not have any issues with fit...go back a page and look at all the pictures of them mounted..
image-710518395-jpg.719439
photo-10-jpg.720695
Lenses:
7L10011 = 15.09" x 5.626" x .125"
7L10077 = 17.4" x 6.79" x .120"
7L10078 = 18.824" x 7.629" x .125"
I'm going to get my order in.... thanks to Mud as usual for great ideas and making me spend more $....
It appears they have new options if they fit a arms....mine measure 16.71...
Do you have the part number for those lenses? This is the info that LTChip was talking about in post #190, which are off of the Engineer Schematics...
#7L10078 has a inward 8 degree curve on the portion closer the hinge.
I do not have the part number ....I think you should just call Dan at Rosen....instead of trying to make sense of the engineering schematics... I'm still confused as to what exactly you guys are trying to determine.... 6 or 7 of us have ordered them and are happy with the fit. If you're looking for something different you should contact Rosen
