Should I replace my radiator?
But doesn't it seem odd that I'm not seeing coolant on the ground? Nothing within the engine bay seems wet or no signs of drops even after parking it overnight in my garage. I would assume if the system was using coolant that the overflow tank would be losing coolant daily, right?
I’ll keep reading, mostly to find out how many more posts it will take to replace a failing/defective radiator. Good luck.
I plan to replace the radiator, but it would be nice to see some sort of actual leak rather than just spending $425 on a new OE radiator.
Buy a cooling system pressure tester if you are not convinced the crusty radiator and crusty hoses are the source of your leak.
The red crust is your sign of numerous leaks. The water content of the coolant has evaporated away because,... It's hot. When the liquid evaporates away, the crust remains. It evaporates before there's any drips on the ground.
Additionally, you're focused on the Coolant Overflow Tank, and while it seems to be receiving the expanding coolant and returning the contracting coolant, it's not a good indicator of coolant level overall, as the crust you show on the top tank seal is likely less than a cup of coolant, evaporating out the liquid, and leaving the residue.
At least we know your Radiator Cap is working as it should. Keep that and throw it in your glove box as a known-good spare part (*but put a new Radiator Cap on your new Radiator regardless!).
@simpsoap
Edit: I basically repeated everything already said above, but maybe the OP will read one of them??
A small but constant leak as already discussed can dry up (the water component) leaving behind the reddish residue, and not have anything show up
on the ground. The leak could be from a leaking hose or hose connection, or a leaking radiator; either a crack in the top tank or even a failed O-ring (gasket) around the inside edge of the top plastic portion (tank) of the radiator.
If you haven't yet, I would scrub the red sludge off from the top of the radiator using a stiff brush, old toothbrush,etc, wash it off well, then dry it off.
As a test you could go ahead and replace the upper radiator hose and the clamps now, using Toyota parts.
With a new OEM hose, new OEM hose clamps and cleaned off radiator check the top of the radiator and hose connection just a few minutes after starting a cold engine. ie: get the engine up to operating temperature in your driveway idling, shut the engine off after say 20 minutes, look for a leak. Come back after 15 minutes and look again during the day. Already mentioned but you can add a DYE INTO RADIATOR which will glow under UV light, that will help finding a small leak.
Also already discussed but you could also buy (or rent at an Autoparts store) a cooling pressure tester and pump up the pressure in the cooling system yourself and look for the leak.
Do not wait a week or even a day of driving before you look for the leak, it should show up in minutes after the system gets hot and pressurized and/or after the engine is shut down.
If/when you replace the radiator you could replace the Thermostat (OEM part) if you don't know it's age.
I completely understand.
Highly confident your radiator is leaking.
I've been driving my LC with a very similar weeping leak on the top of my OEM radiator for over 2 years. My radiator is currently 11 years old (so it started leaking at 9 yo).
I monitor my coolant level at least weekly. Mine is my DD.
Even though the overflow tank is right on, don't forget to confirm that the radiator is completely full as well.
My radiator looks about the same, and has for ~30K miles. After a full day of driving, I'll see fresh wet coolant but never drips.
I have a new OEM radiator in the box in my garage waiting for me to have time to do the swap.
Some additional things you need:
1) Foam strip between the radiator and radiator support on the front side. New OEM radiator comes with new foam strip.
2) Your bottom shield below the radiator is missing. This helps keep the air moving through the radiator and not around it.
3) I recommend the Toyota hose clamps and get away from the worm gear clamps. The worm gear can be overtightened and cause hose damage or be stripped and allow the hose to leak. That may actually be what's happening here. So, maybe new hoses and clamps first.
I will see my overflow tank be low after a long hard trip. I keep both coolant and distilled water in the truck so I always have resources. I also carry oil, grease guns, tools, and a few extra parts, but I will be on the road for sometimes months and I have to bet my life on my truck and I don't always have time to replace things properly, as I do all my own work. There's only one other guy I would trust and the line to his shop is VERY long.
read this link on how i made a pressure tester at home using a Schrader valve from a bike tube and a mountain bike shock pump - it solved the mystery of where my radiator was seeping coolant from a few years back
Do you know the part number for the "bottom shield" you mention above that you say is missing?
I want to make sure to order all the parts and have them all to replace.
Thank you,
Andy
There is a splash shield (Engine Cover Under #1; 51441-60190) located above the steering stabilizer that bolts up under the radiator. Not super critical IME unless maybe you cross deep water regularly?? I've driven a few hundred thousand miles (on pavement) with that shield removed without any issues FWIW.
Without the shield you can better see what's happening at the lower front of the engine, with the shield in place oil leaks (and dirt) tend to collect
on top of the pan/shield instead of dropping to the ground, so take your pick.
If you decide to install the splash shield (51441-60190) it appears to still be available new, you'll also need four bolts to attach it (90119-08863)
I just did a radiator replacement, couldn't find an OEM in this part of the world, managed to get and install a Chinese one that didn't work. After lots of back and forth I got a radiator from Dubai, made by a European company that specialise in cooling technology, anyway It's been a month since I installed that and no leaks or issues reported so far.
Just wanted to provide an update. Ended up replacing the radiator with OE, all hoses, new clamps, Toyota Red Coolant - truck is running great. I was surprised to see how beat up the old radiator was, but perhaps that is typical. The new one looked great, and actually slightly different that what was in the truck, perhaps it wasn't OE or maybe a used one was put in. Temps have been running around 181* which seems great. Thank you all for the help, I also was able to find the belly pan that another member mentioned and I added that as well.
-Andy
It amazes me by some of the comments on this forum and within this thread. All along I was planning to replace the radiator, but I wanted to get thoughts from others that had similar experiences. Contrary to what on here think, I was dragging my feet to see how many posts it would take to replace the radiator.
I thought this was a place to get helpful information from fellow-minded enthusiasts!?!
-Andy
"I thought this was a place to get helpful information from fellow-minded enthusiasts!?!"
It is, just sometimes the forum pokes the bear, particularly if it seems like he's asleep. ;)
Just go with the flow, like water in a cup, become the water, or the cup, or?? (watch the video).
It's all good.
-Andy
Just giving you a hard time man, it's how this place survives. If it hadn't already been said thirty times before I found the thread, I looked at the very first picture and said, "That guy needs a new radiator, ASAP."
In the mean time, you got good advice about the foam surround, different opinions on the splash shield, and (jokes aside) we're all happy to see people keep their rigs on the road. In the end, that really is why we're all here.
Agreed. My rig has been through it, but I want to keep it running in tip top condition if I can. Hit a deer in Dec 2019 before COVID hit the fan and brought her back to life from that. Sitting at 332k and counting. It's hard telling sometimes if people mean it in good fun, or are being dicks. I've seen it plenty on other forums.
-Andy
I have replaced radiators on my 91 like 5 times during my 10 yrs of ownership. You will get used to it and it will be like changing oil......
Many from trying new aftermarket radiators and a couple times due to user errors...
