Builds rocks and rolls (1 Viewer)
That is one hell of a great idea, I have struggled with engine hoists straps and whatever I can move the engine with and hope it does not move while making the engine mounts.
I did not take a good picture of the adjustable engine jig (green) that fits between the frame rails and allows you to make laterial adjustments before I fabricated to the scab plates and the chevy OEM engine mounts. Off set the engine 3/4 of inch for proper drive line allignement
Dude .. is your front ARB air line run out of the front of your front 3rd member . ? little exposed .. nice buildup ( pretty fast ! )
A couple of engine pics. Dual battery trays. Loose wiring for the front end lights etc.. Loose wiring for the TBI and and controller. Placed relays on a alumunum panel that mounts on the firewall hood ridge..
Running all around disk brakes. Chevy monte carlo calipers in the rear and toyota OEM calipers up front. Running all steel braided lines with a brake lock inside the cab. I found an unusual master cylinder at the swap meat in Long Beach that is the operates off the same principle as a big rig. The master cylinder has a compressor and an accumulator which stores pressure. Even after the vehicle is not running (no vacuum to the booster/traditional breaking system) I still have over 20 power pumps at the pedel.
I mounted the the engine and drive train as high into the body as possible and as a result I had to fabricate a new radiator mounting straps that lift the raditor 3inches in order to center the raditor to the fan.
Used two pieces of channel mounted to a stud that attaches to the stock placement of the cross member.
I ran two verticall rods which attache to another piece of channel on the top of the radiator. The vertical rods then tighten with nuts.
Fabricated a fan shroud that attaches to the bottom pieces of channel and to the top of the channel.
The radiator then attches to the firewall with two addjustable heim joints (rods).
I went crazy and went with extra wide Davis alumunum radiator that I got for half price. The radiator cools extremely well 190 to 210. The only draw back to the extra wide radiator was that it was a tight fit between the headlight buckets and I had to use two different radiator hoses and mate them together.
you got a part number on that radiator or source were to get one?
Couple of pics of the steering correction and the front ends rear shackles. I used a hole saw and drilled thru the frame and then used the OEM shackle hanger and machined it down to fit thru the frame. Using OEM bushings. The steering correction takes a beating so I welded some small plates to front to as gussetts. Welded some tabs to the bumper and used a old winch fairlead as a roller. Works pretty good when trying to get up on obstacles.
Made some supper long shackles for the front and then the worst thing happened the dredded front end wobles. I made a removable panhard bar. I have since fixed the shackles and dont use the panhard bar. Using a rancho 9000 as a steering stabilizer. Lots of adjustment..
Had alcan springs make a pair of leaf springs with the orbit eye. The springs are amazing. I then used scissor shackles. I then removed the stock shackle hanger and used a piece of rectangle rim stock and used them as shackle hangers. The springs are much longer and I pushed my wheel base back to a little over 98 inches. I bearly clear the rear gas tank at full compression..
Nice the panhard adition .. ( I thought I need to do something like in my Tencha ) .. I'm still thinking in you rear shackles .. how they perform under a heavy braking situation .?
Thanks for the compliments. All around disks brakes I have the best stopping power I have ever had in a TLC. Absolutely no issues with springs or shackles in heavy breaking. I will upload pictures this weekend.
Cut about 3 or more inches off the rocker panel. Fabricated some rock sliders. Welded 3 oversized scab plates to the frame then drilled and tapped. Then fabricated some square stock extensions. I like the design because they are strong and removable. I then used some diamond plate aluminum sheet and cut it to match the underside of the rock sliders. Drilled and tapped with inset allen heads. They work great.
Worked on the skid plate. Took two pieces of angle iron and bolted them to a frame. I then took some steel plate and welded to the angle iron. I had to make provisions around the the t-case. Lots of heat....
