- Thread starter
- #101
I realize that since I'm usually the one spending other people's money I deserve this, but dayum ya'll. Twin's would seriously put me in Dutch with the wife.
I hesitated on the red just because almost every rebuild I see is doing it now, to the point it has almost become cliché. We'll see what other matching goodies can nestle in there with the valve cover.
Next few days are sort of booked with either school or holiday items so progress will be slow.
Still on the list:
Upper pan (bare aluminum or paint?)
Lower pan
Rear main seal
exhaust manifolds (will run the engine NA for a while before any turbo stuff happens)
lower and upper Intake manifolds (Do not plan to do EGR delete until turbo)
Power steering pump
alternator brackets and alternator
pulleys and belts
AC brackets
Distributor/plugs/wires, etc. Set static timing.
PHH and other hoses
PAIR valve
T-stat and water neck.
Oil filter
Prime oiling system
Some items will be swapped off the old motor when it comes out:
flex plate
starter
throttle body along with TPS and IAC (I believe, maybe, not sure yet)
Still on the list:
Lower pan
Rear main seal
Power steering pump
pulleys and belts
AC brackets
PHH and other hoses
PAIR valve
Oil filter
Prime oiling system
flex plate
starter
