Builds RevISK’s ‘80 FJ40 - A Girl Named Norman (1 Viewer)
Looks like they have a good line up of BBQ. That's worth the trip.
Funny thing is I only recognize a couple bbq joints. But hey, if you’re doing bbq in Texas and suck, you last less time than it takes to smoke your first brisket.
I’m trying to convince my wife that we should fly to to Texas for the Troubadour Festival in Aggie land in May, I’m sure I’ll have teenage kid stuff to take care of though and we won’t be able to go.
I just want to go pig out on smoked beef, drink dark beer, and enjoy some live music!!
I know it’s not in the neighborhood but you’ve always got a place to stay in sunset valley.
B double E double R U N….. Beer Run
i need to find that mp3 file I have of that
If my brain is correct, what’s that spell, is one of the lyrics
@Ol Yeller here is the first verse:
Be -double E double are you-N-beer run
All we need is a ten and five-er,
Car and key and a sober driver,
A couple of frat guys from abilene
Drove out all night to see Robert Earl Keen
At the K-pei swine and sworay dance-
They wore baseball caps and khaki pants-
They wanted cigarettes-so to save a little money-
They got one from this hippie who smelt kina funny
And-next thing they knew they were both pretty hungry-
And pretty thirsty tooo
So this picture serves two purposes, A) mission accomplished. 2) on the way back I hammered the girl in second and got no flat spot. Does the cold or coolish engine matter?
Yeah I’m thinking in that direction too. They look real nice in the 40. My stock seats are shot so might go the procar option too.
My oem seat aren’t even fit for a dog bed. My middle third suffered every time I drove this girl.
Knowing that I wouldn’t be able to commit the time to really redo all the metal plus the damn shipping costs of just the SOR foam, I opted for this route knowing I could offload these for at least half down the road. Like I said earlier in this thread, $670 ish to my door and no more than 1/2 hour to swap them in… gold when I sat in them the first time.
I only wish they came out of the box with a heater option, that is my biggest reason for not already having them in 40.
But, with enough time and money anything is possible.
(Neither of which I have to spare)
Heater is definitely going in my oem rebuild whenever that happens. These procars are budget enough to give it a go I would think?
Do you have a fuel pressure regulator? I learned during my visit to BTS/Man-a-Fre in Nevada that the factory mechanical fuel pump puts out more pressure than the Weber wants. They actually like the Weber on their 2F rebuilds.
I don’t. I’ve looked into it and have read so much conflicting info I just let it be. Maybe I’ll pick one up and give it a shot. Around 3 psi if my memory serves me correctly.
The strange thing is the intermittent nature 🤷🏽
Regardless, thanks for the reminder, I forgot about this.
Couldn't hurt. I'm going to put one on the Weber on my 45.
Another thought. Anytime there's an intermittent issue, my inner voice whispers "check yer grounds".
Have you checked your tank for rust? If it resembles what you pulled out of your cooling system then that would be my guess. Also check for trash in the lines or better yet replace the lines as its not expensive for a length of 5/16 fuel line from any parts store.
Lines are a good call. There probably is some rust in the tank as evidenced by the fuel filter I just swapped out. I'll start with the lines and regulator then look at draining the tank and assess from there. Short of replacing the tank, what's a good fix if there is major rust (I don't think there is)? A bladder? I'll do a search of course, but since we're talking about it...
I went through all my grounds fairly recently but good call nonetheless.
I'd love see your 45 sometime, I'll bring a rag to keep my drool at bay...
Take the sending unit out of the tank and see what condition it’s in. If it’s covered in rust then you will likely need a new tank. From others on here a poly tank has its own set of issues but the oem steel tank would be best followed by a replica such as from cool cruisers of Texas. Oem tanks are spendy but it solves the problem and you won’t have to worry about fit or leaks. I bit the bullet with a new oem tank, pump, filter, and lines and it fixed my intermittent problem along with the city racer carb. Also blow out the metal lines with compressed air. Some have had success with chemical cleaning and resealing the tank but depends on condition.
Instead of working, I just went down a rabbit hole of gas tank rust repairs... I've got a really seized bolt on my sending unit cover that I've never really bothered to deal with so I've never had that cover off. I'll start soaking in CorrosionX and get after it with the impact screw driver later today. I'm hoping I'm good here with the tank. I still need to finish up the hardtop repairs and need a new rain gutter and all new seals so I'll be throwing about a grand at that.
Fingers crossed...
