Pretty quiet in here... what are you working on? (6 Viewers)
I can snap a picture of the third.
@cruiseroutfit - get the fj55 iron pig sticker I sent ya?
[QUOTE="Jakes40, post: 12983464, member: 501I also have corse spline drive shaft you can swap out the drive shaft. But that seams like a lot of work.
[/QUOTE]
If the flange splines are different...
You can just take the lower part of a coarse spline drive shaft and mate it to the yoke of the later driveshaft. Should be able to do it without unbolting the yoke from the TC.
Happy to help. We have all of the different pinion flange variations available too!
Do you have the round flange that can be mated to a coarse (10) spline pinion from a '71? I have some spare drive shafts that are the large pattern from the later model FJ40's.
Can't I just take the flange off of Jack's pinion and swap it on the pumpkin from BK?
no you will not be able to do that Jacks is fine spline and BK’s is course spline but looking at the chart you should be good to just bolt it up. And you can just change the drive shaft yoke to a matching bolt pattern yoke. I should have a small yoke if you do need it.
According to that chart, fine spline was not started until 7/1978 and Jack's truck is 2/1978 so think it is good to go.
get it and see. but there have always been a odd ball here and there. or one got changed over the years for one reason or another. I know I have a driveshaft flange that will work if the one you have doesn't. If needed its yours. just give me a day or two to dig it out.
You're awesome. Thanks Matt.
Yes I did... and it is in my cherished sticker collection. Eventually I'm going to find a fun way to display them at the shop!
Thank you!!! :cool:
Got the last of the hoses today and got them on. The only non-OEM hoses I used— some Gates green stripe and some Us for the rear heater.
The beast lives and hasn’t thrown any parts off the front of the engine yet!
Runs right around 3/8ths now just like our 100 series. The truck never got much above the bottom of the gauge, never above 1/4, and the heat was always luke warm. Maybe I’ll pick up a whole mpg now that it gets in the right range!
now just need to drain the distilled water I put in and add the red juice/distilled water mix. Switching from green to the Toyota stuff.
Feeling good— this is my first time doing a water pump, thermostat, etc. and any kind of seal replacement/timing cover/getting that deep. Confidence was low after my botched master cylinder change even though it was a bad part. I just hope I’m not celebrating prematurely.
View attachment 2258146View attachment 2258147View attachment 2258148View attachment 2258149
Great job! This was the 1st job I ever did on my 40, waaaay back in 1997.
Pretty bored waiting on parts for the 40. My brother donated this 80's vintage Kawasaki Bayou 185 to my yard several years ago in non-running condition. Decided yesterday to drag it up to the garage and see if I can get it running. Looks like it wasn't much of a popular model so parts are hard to find. Right now trying to get the rear drum unseized. Motor turns over but carb looks pretty cruddy. For some reason Kawasaki decided to put an electric fuel pump in this thing so that will be my first test.
Those old three wheelers are so fun and dangerous. I want one! Just don’t put your foot down while cornering.
I was so used to riding dirt bikes, that when I got on the 3 wheeler I would run over my foot constantly. Fortunately it had worn out tires so it didn't suck my foot under.
But they are f-ing dangerous, especially in down hill turns and off camber terrain, or just a guaranteed eventual trip to the emergency room.
  • GGM
