- Joined
- Jun 6, 2005
- Threads
- 74
- Messages
- 1,395
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
Hey Guys
Sharing the news for the new product that Powerbrake just came out with, now in stock here in the US.
The previous big brake kit for the 80 Series would only suit 17" or larger wheels to clear the large size of the bigger 6-Piston calipers they run. They have come up with a new smaller sized 6-Piston caliper now so that they can cater to other 4x4's with 16" wheels as standard (70's, LR Defenders, etc), so this will help broaden the product range. These use a 13" rotor now instead of the 13.7" that the other kit uses. Note: Some OEM wheels have a very tight offset and could still make contact with the calipers, so wheel spacers may be necessary.
Full product info is here: Powerbrake Stage 2 Toyota Land Cruiser 80 Series Big Brake Kit - https://exitoffroad.com/product/powerbrake-stage-2-80-series-land-cruiser-front-big-brake-kit-16-wheels/
Price as of today is $3350
- This is the kit for 16″ Wheels. There’s a different bigger kit for 17″+ wheels
- Powerbrake will be adding small wheel spacers to help fit some OEM wheels with very tight clearances
- Some OEM wheels may still require a wheel spacer for proper caliper clearance
- X-Line billet 6-piston off-road calipers (pair)
- High-performance brake pads, pre-loaded into the calipers
- 2-Piece 13″ 72-vane rotors
- Semi-float disc drive system allows for radial disc expansion and contraction
- Curved, directional cooling vanes
- Billet caliper mounting brackets
- Stainless steel braided brake lines
- Provided brake lines connect the caliper to the axle housing, then extended brake lines (sold separately) can be used as well for taller lift kits, connecting from the axle to the frame
- All necessary mounting hardware for quick, easy bolt-on installation
- Comprehensive fitment and bed-in instructions
- Now Includes Upgraded Powerbrake Pads, PB05 Compound – highest level 4×4 brake pads available – made in Japan
- Manufactured, finished and packaged 100% in South Africa
- Calipers are offered Red Anodized, or Grey Hard Anodized
Caliper Maximum Temperature Recording (MTR) System
All Powerbrake X-Line 4×4 calipers feature our MTR system. The system provides a permanent record of the maximum operating temperature reached by the caliper. Feedback from our R-Line race customers has been extremely positive with regards to the MTR system over the years. We therefore decided to apply this same technology to our X-Line 4×4 calipers. Customers will really appreciate this feature as it provides valuable data in the support of brake fluid choice etc. The inclusion of a Max Temp Recording system on civilian big brake kit range at no extra charge is unique to Powerbrake on the world market.Full product info is here: Powerbrake Stage 2 Toyota Land Cruiser 80 Series Big Brake Kit - https://exitoffroad.com/product/powerbrake-stage-2-80-series-land-cruiser-front-big-brake-kit-16-wheels/
