PabloCruise
Shafts should be similar, but the bolt pattern of the flanges on the t-case, shaft, and 3rd member likely will be different...
Looks like they went from 10mm bolts to 11mm as well:
Good info. Thank you. Since I will be putting new u-joints in, I might get lucky and be able to use the flanges from the '76 and the '70 shaft (?)Looks like they went from 10mm bolts to 11mm as well:
I hope to get lucky here $$ wise because I'd rather save for an H55/split case swap, which will need driveshafts modded then.
I can see it happening.Lived it. I feel you. I remember the second side went much faster
I've removed more than one rivet and if you use a good quality sharp drill bit and drill the rivet first this isn't a hard job, less than 30 minuets to remove both my rear hangers.If you haven’t already removed the other rivets @J Mack recommended a great method
I'll try that, thanks.I have that same beefy spring pack on the floor waiting, will be interesting to see how many leaves you take out.
If you haven’t already removed the other rivets @J Mack recomended a great method...drill the rivet after grinding the head to release some tension then it’ll pop right out with the air chisel, works good.
