- Thread starter
- #141
Dually Tubes, spindles, and axle shafts were identical between the Dually and Van axles. The only difference on the Dually is the wheel flange offset and drum mount on the Hubs (important for a rear axle) and the location of the brake mount flange, spring perches, shock mounts on the housing (all got cut off both housings anyway). So, long story short, the dually housings should be fine for the front axle swap, but if you get a Van axle for the front, you also get spare hubs.
When I did the cost/benefit analysis on the brand new cab vs. reapiring the mine truck cab, plus the bonus of having a spare cab for mock-up and fabrication, not to mention just having the spare cab in the event of a roll over or something or my inexperience with and dislike of body work and the resulting cost of outsourcing that work... it just made a lot of sense to buy Crusher's Cab.
