Official 37" and up picture thread (12 Viewers)
Whatever keeps the tires out of the sheetmetal unless you're doing high speed desert stuff or jumping it, then it might be worth looking at something a bit more fancy. The Timbrens seem to be a good middle ground.
Can't find pic of the Timbrens for the front. Do you have pic of them installed? I can only find info. on rear
3" dobinson dual rate coils, fox 2.0 shocks, 2.5 castor correction, 1.5 wheel spacers, sitting on 17" stealth 6 SCS wheels. 37x12.60.17 nitto G2
1945991
Joined the club last week. 37x12.50r16 Irok ND's. OME 851/860, 1" spacer in the rear, lowered bumpstops. 4.88's. Trimmed the lip off the rear fenders and cut the backside of the inner fenders up front. Very little rubbing and the tires are awesome so far!
Always wanted a set of these 9.00 tires. There a 255/100r16 xzl Michelin. Got a good deal on them used so through them on. There a bit loud on the highway. Haven't taken them out on the dirt yet. As far as looks go there right on. I'm hoping they perform at least somewhat decent in the dirt. They measure the same height as my 37" stt pros.
New to me wheels (Raceline beadlocks), and brand new BFG KM3’s 37x12.5.
Got the 4 used wheels for 650 bucks!
Just bought a matching 5th spare for 460!
Glad I found the deal i got for the 4
Always wanted a set of these 9.00 tires. There a 255/100r16 zxl Michelin. Got a good deal on them used so through them on. There a bit loud on the highway. Haven't taken them out on the dirt yet. As far as looks go there right on. I'm hoping they perform at least somewhat decent in the dirt. They measure the same height as my 37" stt pros.
A superbly robust tyre. I wouldn’t run anything else.
its been a lot of years since i updated
LS swapped, 37x12.5x17 MTR's on trail ready beadlocks, OME competion coils in the front and OMEheavy duty j's in the rear!
How do those KM3 sound while traveling surface streets and highway? When I go to 37s I am going with the KM3. How is the ride quality? I can see they have a lower load range then my KO2, is it a pretty smooth ride.
7.5” wide
5.5” bs i believe*
No spacers
No rubbing? I’m surprised you found a shop that would put those wide tires on a narrow rim.
Just went on today so haven't flexed for fit check but ive essentially run this combo before with tundra alloys and 3 other 37” mfg with little to no problem. Truxxs, cooper, irocks all worked*
I do rub the rear frame rail at full stuff and just a hair on the top liner of wheel well. Should probably adjust the bumpstop down but its been fine since 07 as is and i rattle can thw frame 2x a year. The inner edge lugs of the iroks would barely grab the control arm up front at full steering lock but were 13.5” These falkens in level ground did not.
Yeah. Small local chain. Big box stores are getting rediculous with liability. Best one yet is we cannot mount a 35 on that rim...... but a 315 is fine. Thanks discount tire.
