- Thread starter
- #1,921
I've got a question for you guys about shaving this axle. It has a drain plug at the bottom of the diff so a quick 1.25" shave is not going to work, since I'd be cutting right through the plug. I'm not sure if the Ballistic Fab shave kit will work, so I've got a letter out to them. I can grind off about 3/4" of the axle without getting into the drain plug, so I think I'm going to do that.
My question is, should I spend the money on the Ballistic fab shave kit, then the money on turning the ring gear down and then having the housing welded, or should I just run the diff un-shaved? The money on the shave kit could very easily be spent elsewhere and I'm thinking that'd be the smart thing to do. Then again, it'd be easier to do it now and get it over with. Advice?
In other news, tore into my new axle yesterday. The ring gear and carrier of these axles are insanely huge. Here's a picture of a 4.10 (41-10) geared gov-lock carrier.
I found this unexpected difference between the two axles. The new style hubs are shorter and have a thicker wheel mounting flange:
In this picture you can see the bearing supported pinion and carrier bearing adjusters. No need for shims on this bad boy, just tighten and loosen the adjusters as needed. SUPER slick.
Finally, look at the 9.5" ring and pinion next to the 10.5" ring and pinion. The difference is obvious and shows why this axle is so much more heavy duty than the LC stuff.
After this I threw the 3.73 open carrier and pinion into the newer axle. I haven't set it up yet because I'm not sure what to do about shaving. Any advice is appreciated!
