Are you guys looking at the Vintage Air "Monster SuperFlow" condenser 16" tall x 27" wide x 1" thick ?
If so, looks to me like the in and out ports would have to go through holes bored in the car body - passenger side radiator frame.
Let me throw a possibly interesting twist into this plot.
1999 Lexus GS300 condenser is a definite match for the description and picture
@flintknapper showed for the "Sub-Cool Modular" design (which is also microtube parallel flow). (I have this car)
Looks like it will fit extremely well.
Vertical is a very tight fit - but does.
I measured with a "story stick" and get about 2mm gap.
Going from the Landcruiser frame, at the bottom ends where it is highest - to the underside of the top rail - where the hood latch attached.
The top edge of this condenser would be hiding from view.
Horizontal has probably a finger width at each end.
This would be very easy to fill the end gaps with foam and get full air flow through it.
Much better than the OEM unit.
This condenser has the receiver/dryer gas separator tube on the passenger side.
The dryer is some kind of cartridge or "sock" with stuff in it, that inserts from the bottom.
It would need a fairly simple vapor line extension, from the stock Landcruiser fitting on passenger side, crossing the face of the condenser to the intake port on drivers side.
Liquid line output port is about the right place.
Bottom support feet would move inward a few inches to a custom bracket in the Landcruiser frame valley.
Looks like they just unscrew.
These are readily available from several manufacturers from $60 - $120 (rockauto).
