with so many people w/ part times put in, it's a really good question, hehLook good to me. That was on a full time AWD?
I am under the impression that it is not the seal that deforms and allows leakage. It is that the seal is harder than the OEM and grooves the shaft allowing leakage. How do the shafts look?
Stock axle breather cap? or have you removed the check valve?
toyteg08: did you do the front axle service for routine maintenance?
FWIW it's been 40,000 miles since installing Marlin seals with my original ~300,000 mile grooved axle shafts (and side-swapped modified grease-able 300K birfields); no soup, no leaks, no clicks. But then the OEM seals lasted almost 200,000 miles before they leaked based on the maintenance records. IMO the soup starts when the wear grooves in the shafts get too deep for the OEM seal lips to seal effectively. As mentioned above and IME the Marlin seal has deeper/wider/tighter lips that seal better with grooved axle shafts.
