I bought a well maintained ‘97 LX450 from a neighbor a few weeks ago. It has 188K miles, just had an oil change and it was running like a top before I took it to a local Midas yesterday for new belts (a/c, alternator and v-belt). Midas also replaced the fluid in both differentials and my transfer case with Valvoline 80W-90.
While driving back to my house from Midas yesterday, I noticed that the vehicle was rocking a bit, while at a stoplight. I continued to drive home and then the vehicle sat in my driveway for a few hours before I drove it roughly 3 miles before the check engine light came on and the engine sounded like it was missing while also rocking quite a bit.
I started to drive it to Midas this morning and I noticed the temp gauge jump from cold to hot in under two miles. Long story short, I immediately pulled over and had it towed back to Midas. The radiator had little to no coolant when it was towed into Midas. The technician filled it with coolant and ran the engine with the radiator cap removed; the coolant bubbled quite a bit. He then ran a head gasket test via the radiator and the fluid in the test kit changed from blue to yellow almost immediately.
-The oil dipstick shows full and the oil is very clean & honey brown in color.
-There was no sludge or water.
-The coolant looks bright green (previous owner had an after market radiator installed at 160K miles).
-There is no milky white residue on the underside of either the oil cap or the radiator cap.
I had the vehicle evaluated by three different mechanics before I purchased it.
Is this just incredibly unlucky or a bit suspect given that the vehicle melted down immediately after Midas worked on it? I had the vehicle towed to a local foreign car specialist in San Diego so I should know more tomorrow. Thanks in advance for the help.
