I'm having similar issues after removing the bib and doing a bunch of engine work. If I find a solution, I'll post it.After all the work this winter, body mounts and remove the front bib to install the headlight upgrade, I now have body fit/alignment issue. The hood is totally misaligned with the fenders/bib. Any hints to deal with the alignment issue would be appreciated. I don't know if the truck has been in an incident or whether the frame is bent.
The gap existed before I did the work this winter however it was not take large.
Did a combination of the body mount replacement and bib drop create the issue?
Is there a sequence for mounting the fenders to the tub?
Driver's side
View attachment 3294894View attachment 3294895
Hood is sticking out 1/2" from the passenger fender/bib.
The gap between the hood and front cowl is fairly even.
Just found this. I know I should always do the search before asking the question. Found this link using google search. Going to try this next weekend.I'm having similar issues after removing the bib and doing a bunch of engine work. If I find a solution, I'll post it.
Toyota Headlight Upgrade has been installed. I do wonder what Toyota had in mind when they created the kit.
Thanks for the information.Unless you have a kit I never heard of this kit was made for a different Land Cruiser model not the 40 series. This was not a universal kit one size fit all design but make for certain model. The cost of the kit is so cheap just having a harness that isolates the new headlight from the old harness made it worth it. Better than starting from scratch on a new harness. I would never upgrade headlights and put the load on the fifty year old harness.
Winter Projects Finished. Now it is time to drive it.
Completed the headlight /fog light alignment after the bucket cleanup/ headlight replacement. Put tape on the garage door for the adjustment setup based on the details in the FSM. Don't forget to put headlight on to high beams when doing the adjustments. Light upgrade was worth it.
This is for right hand drive, right?
