LC & LX470 Tesla Style Screen Radio Upgrade with Climate Control: General Discussions (4 Viewers)
Mine looked like that until I fussed around with the cables behind. They were in the way. Might not be the same. But eventually mine seated in decently. Still protrudes a bit here and there but it’s fine at first few glances.
Thanks. Ya, I checked that and got the wires out of the way- but regardless of wires, the two panels plus the head unit are wider than my cavity- just 2-3 mm, but still too wide. I'll look at it again before I disassemble and send it back.
I had the same issue with TLC 100, using phoenix unit and the side panels that came with unit. But installing unit with OEM TLC panels worked just fine. Apparently panels that came with unit a little bit bigger than OEM.
Ya but different issue. The unit plus 2 side panels are just too wide for the cavity.
You can buy a Teyes CC3 or similar screen and the necessary trim from Aliexpress.
Hello Mud Community,
Over the last 9 months there has been some great headway made on the ZhiFang 12.1" Tesla style touchscreen radio with integrated climate controls. There are a few dedicated threads to specific installs and I figured it was about time to create a general discussion forum as lots of good install info if getting buried in these threads.
For those of you who have not seen this yet it seems to have started here: Tesla style head unit - has anyone seen this?
Specific installation experiences have been documented here:
Successfully installed a Tesla Style headunit into a 2005 LX470
"Tesla Style" found for older LX470/LC100
2003 LC Tesla Screen Install Write-Up
Here is what they look like: ( mistered123 I hope you're ok with me snagging your pics for reference)
BEFORE
2027404
AFTER
2027406
The quad core units were the first batch to come out late last year. Part #s are ZF-1301S. These used Android 7.1 and (once the wiring issues were worked out) they worked pretty well. Overall the hardware and OS where described as a little clunky, but a definite improvement over the original touch screen radios and cassette decks.
The six core units (PX6) are the latest batch out as a release of this post and are pretty good. Part # for the LC version is ZF-1301X. These are not showing up on the ZhiFang website yet, but they have ZhiFang's name on them. They look to have the same cables as the original quad core units but have worked through most of the wiring issues. Interfaces are crisp and fast with the only general complaint is the amount of time it takes to start up once you turn your key on. This is typically around 20 seconds. AC controls work great and utilize existing Toyota circuit boards as part of your original radio.
I'd like to send out BIG thanks to mistered123, LX470MK, Swainbuilt, Wetwillie, revoked, loeky, Ell Ex & all the others that have contributed so far with testing and Q&A.
These units are sold by a variety of online resellers, but they seem to be made by one manufacturer in China. They don't come with assembly or operations instructions...AND the technical support is lacking. Some have been buying from a US based radio shop, but it sounds like they were just buying these radios in bulk from China. Here is where you can find the PX6 chip set radios online for purchase:
The only thing I can tell different between the LX and LC versions is the additional side trim for the air vents as the LX trim tends to be in three pieces (one running the full width of the cassette deck) and the LC already has the appropriate vents.
Ell Ex has done a successful full install of the PX6 (6 core) units with Android in a 2006 LX470 with ML amp and custom apps. I'm in the middle of a full amp and speaker replacement with a 2004 LX470 and the PX6 unit. A few others have been working on 2003 and older installs. I've heard of a few people wanting to try these with non-nav (dedicated AC control version) 100 series trucks, but have not seen one yet.
The 2004 and newer seem to be plug and play for cables (once you figure out where they all go). There seem to still be a few extra plugs left over (3 in my case) that may have been part of the factory test.
The 2003 and older units are needing either another harness from the manufacturer or a few wire splices to work. There was a request for the "Top Model" wire harness for these truck to avoid splicing, but I cannot confirm its the final solution.
No confirmations I can find yet for getting the factory backup camera working. I'm looking at installing a new HD camera now to replace the 16 year old factory one. One in the back and one up front hopefully.
I am hoping to write up a first draft of an installation guide for my experiences on a full amp replacement and am willing to share with others to alter for 2003 and older versions as well as ML integrations/tips/tricks.
My hope is that this can be a source for good general information on the radio installs, applications, mods and troubleshooting and the model specific threads can serve those specific needs without getting cluttered with off topic discussions.
Hope you all find this helpful. I'll try to get my install guide uploaded soon.
PLEASE ADD YOUR EXPERIENCES AND COMMENTS.
11/05/19 Update: Version 0.0 of the Install Guide Uploaded. Please review and private message me if you have suggestions for improvements or additions. Would really like to add sections for 2003 and older installs and any other variations seen. Also, any suggestions for App are appreciated.
I was looking on the Phoenix Auto website today the 21 st of Feb 2024 and they are offering what I think is an Android 9 version of the vertical display for a 2004 Lexus LX470. Has anyone installed this newer version? Any issues? The website claims that it boots faster.
Unfortunately not mate. I deciphered both electrical diagrams and worked out was going on and then wired it in a way I thought would work but I just couldn't get any response from the AC button part of the unit. I think the issue may be that the US cruisers have another ecu called the Gateway ECU in between the nav screen and the AC amplifier (ECU) whereas the JDM cruiser is straight from the nav screen to the AC amplifier (ECU). So I'm thinking the CAN box that comes with the unit just isn't chatting the right way to work. Would really require someone who can record them emulate the CAN signals from the original nav screen to get it working. I'm hoping the Chinese are doing this but it wouldn't hurt to message them and request it as well.
The only good thing that's come out of it is there was a mix up because of the time it took and them sain initially it would work so I've had my money refunded and still have the unit! Not bad considering it was a touch over $1k AUD. I'll keep investigating. I may be able to work something out now I've still got the unit to play with.
Hey, it's been a while. Did you ever find a solution or viable product for your screen replacement? Not a whole lot of people out there that are in our predicament.
At this point I'm considering just biting the bullet and trying to pick up a "3-knob" control panel.
For audio sake has anyone ever tried putting a single din in the console to replace the 6 disc changer and run all wires to it. They all come with remotes today so you wouldn’t exactly need to see the unit and almost everyone plays music off of their cell phone these days via Bluetooth. I imagine some trimming may be needed and of corse extending all wires to the console may be a bit of a pain. But it may be a viable option to get premium sound when combined with an aftermarket amp and new speakers. Someone will likely come in and tell me how stupid this idea is lol.
Just for audio: I’ve seen a post somewhere… the guy bought cheap BT to headset adapter, went in into the stock tape deck, found tape’s preamp output, connected BT adapter there and removed all tape related guts.
Hey, no I haven't moved forward with this. I did message the company recently to see if they'd progressed with it (they told me they had a russian customer trying to help them) but they replied that they hadn't had any success so far.
I'm also keeping an eye out for a 3 dial climate control panel, seems the only way out of it :confused:
Got this installed in my son's 07 lc. No sound everything else seems to work. Any suggestions
Go to sound field delay screen and set each speaker to a different value. Worked for me but it sounded like s***. But it worked. Ordered a px6 unit to swap out the g6
Settings > Settings > Audio > Equalizer > Scroll all the way right > "Sound Field Delay"
Set each of the 4 values to something different until you get acceptable sound.
Such a bummer. I'll ping them sometime this week as well.
I've been searching for a 3 dial but its gotten nearly impossible to find one with the pigtails.
Phoenix update. Gave up on the newer g6 unit. Ordered and installed a used px6.
It works perfectly. No hum. All speakers work normally. OEM backup works. I installed sergeys software today just to make it look better. And it does.
G6 was quicker from startup to CarPlay but px6 actually works.
This is great to hear and I'm considering doing the same... Did you have to do anything to get the OEM camera to work? Also, did you buy Sergey's software from them, or find it somewhere else?
  • Back
