I would love to see a rendering of a GX550 that is built up a bit. Anyone think that aftermarket suspension lift and armor will be ready for the launch? I bet it would be a tight rig
Fwiw, LC300 owners don't seem to be having an issue with ekdss lean on the 300 post lift..compared to some 200 with kdss.I like the Overtrail+, but i imagine aftermarket lifts would spoil the E-KDSS right?
I guess my question was whether the system works the same. I’d assume the its calibrated to work with specific baseline spring/shock lengths, but I know virtually nothing about it tbh.Fwiw, LC300 owners don't seem to be having an issue with ekdss lean on the 300 post lift..compared to some 200 with kdss.
Lots of lc 300 grs that come ekdss standard running aftermarket suspension here.
OVERTRAIL PROJECT
Cool video...wish the video was properly translated from Japanese to English.
Wish there were more info on the interior and other capabilities.
Is that color incognito?
This makes me feel better about my color choice. Looks great.I think yes
Does eKDSS solve the lean issue because it's more an active electronic system vs passive hydraulic system that can become unbalanced?I guess my question was whether the system works the same. I’d assume the its calibrated to work with specific baseline spring/shock lengths, but I know virtually nothing about it tbh.
You can translate, just select settings and auto generate subtitles to English. It catches most of what they are saying.Cool video...wish the video was properly translated from Japanese to English.
The lean was because it was imbalanced. It had two cylinders on one side and the internal pressure was around 500psi. The pistons are double acting, but there's still a significant difference in area of applied force due to the large shaft diameter. The result is a constant net down force on the sway bars on the driver's side of maybe 200lbs or something like that. I've calculated it in the past but I just don't recall exactly what it is. This is the case even if you "calibrate" or "balance" the system by evening out the pressure between the upper and lower circuits because equal fluid pressure in each side against unequal area results in net piston force trying to extend. There are a few ways to resolve it, but it will tend to return to it's natural balanced pressure state over time anyway. The best long term solution is either shims or springs that are slightly different side to side.Does eKDSS solve the lean issue because it's more an active electronic system vs passive hydraulic system that can become unbalanced?
Interesting. Sounds like Lexus will be introducing all sorts of accessories along with some camping gear for the GX launch.
Do you have any details / information on what's going to be offered?The AAP Program is great. Bilstein, ARB, CBI, Dometic and more.
They've already added stuff to the car builders on Toyota's site, so that may give you some insight as to what they're looking into? I tried to build a Tundra the other day and the list was pretty sizable already.
Do you have a link? I didn't see it on either Toyota or Lexus sites I visited.
