- Thread starter
- #61
Posted over at ls1tech.com about the output carrier. We'll see if they have any other opinions.
4l80e output carrier chipped - LS1TECH
I have a pinout for connectors from my 97LX I did last fall. It has a bunch of other stuff on it as well. Send me a PM and I'll get it over to you.Yes, I got the GM harness completely stripped down and started pulling wires. I'm still looking for an ih1 and ih2 pinout sheet. I've asked around, but I can't seem to find it. So, I'm building my own, it's just that it takes some time from the EWD. If someone has it and could send to me, I would be VERY appreciative of it!
I also had too much crap on my work benches in the garage, so I've been working to clear some of the half started projects out of the garage. One being my OBA system, which I got the compressor switched up and pressured up to test, but then I stupidly don't have a way to bleed off the pressure, so I can't weld my tank up. I need to get power to a diff locker relay to relieve the pressure so I don't take a fitting to the nuts (which would be my luck). Hopefully, I have that finished this afternoon. I also picked up a used slee front bumper last night!![]()
Can you link the one your watching?Been slow. My wife has a parasite and she is insisting I do things around the house to get us ready to house the parasite. Along with the lack of a shop and the snow, motivation to get out there has been low. More snow and rain this weekend....
Been kinda of watching another forum member's swap. He should be dropping in his motor tomorrow and I'm going to check out a different header option. The summit center dumps are a no go, at least with the AA motor mounts. I thought the summit's were the same as the hooker center dumps, but it seems they aren't. Another forum member locally got his hooker center dumps to work, but he ran dirty dingo mounts. So, I don't know if it is a mount issue or the summit headers are different. But, the swap I'm watching more closely we're trying some block huggers that more resemble stock (non center dump).
So...not a lot of traction. I'll be off for a couple weeks when we have the baby, and I plan to hopefully be in wiring hell then. That's 3-4 weeks from now...
