mudgudgeon
Resident galah
BACS is the Boost Altitude Compensation System. It uses vacuum (or the lack therof) to alter the movement of the boost compensator to decrease fueling when over 4K feet in elevation.
So I'll just run constant vacuum on BACS, simulating lower elevation, giving it more fuel, and tune accordingly.
Why not remove the BACS vacuum line completely.
Running constant vacuum, you've effectively rendered BACS redundant, and you're tuning from one baseline with the boost compensator function.
My thoughts would be, remove the vacuum line completely, you'll achieve the same thing, but remove a potential failure point.
If you travel to sea level, fueling may be a bit lean which means lower EGT.
I don't think you'd be down on power as fueling would be the same, but you have denser air.
Fold the belt across itself length ways at a sharp angle, and work the folded belt through the buckle.And the question of the day is... my rear seatbelt buckles are backwards. How would you turn those around?
5 minutes, tops.
