I actually serviced one of those 'beat on sideways' rocker arm hacked 2Fs while I was in Atlanta on vacation before GSMTR last year.
One day Jim, your gonna have to come by and see the Mark's Off Road "Wall of Shame" collection of stuff I've pulled off of crusiers. Hell, between you, me and Whatley, we've probably got enough bastardized parts to build a rig that would scare Frankenstein!![]()
Here's a recently failed crank that was just rebuilt by the guy who builds all the racey car engines.
The problem is after the crank was turned down and polished, then the oil holes in the rod journals were chamfered.
Excessively.
The chamfer takes up more than 1/3 of the bearing width. And it does not have a properly softened edge. The crank shoulda been turned down to within one or two thousandths, then polished to final size. No need to enlarge or chamfer the oil hole, just let the polishing belt soften the edge of the hole.
And yes, that is the shaved off rod bearing hiding inside the hole.
it also serves as extra insurance for your engine by keeping the clean passage ways and bearings from becoming covered in oil and also ensures your motor wont catch fire by preventing sparks from happening inside of the cylinders- and you'll always know where TDC@#1 is just by pulling the dizzy cap...The 2F seams to be a great motor but sometimes my wallet doesn't like the fuel economy, can you stick gerbils or hamsters in side the timing cover to help with that?
I am in the process of reinstalling mine and idk maybe?
If I put more than one in there will they end up fighting to much and not working enough? Or if i just stick one in there will it get lonely and thus not work enough?
The oil filter mount is a flat iron boss and a flat filter base. Very easy to seal.
Therefore it should have a pile of RTV applied to it. Maybe it will extrude enough into the passages to prevent the flow of oil through the filter. This will keep the filter from getting dirty, representing a good savings on maintenance.
