Hello all! It's finally happened, I've been on this site for years as a wannabe and have been doing this build in my head for a long time. I just rescued my 74 fj40 from sitting for 5 years on my Dad's farm. It was my first car, my Grandpa gave it to me 15 years ago, he was the second owner and bought it when it was a year old. I drove it for 10 years on and off until I had to park it becuse of the rust. It had been sitting for 5 years up until now and it fired right up no problem! My Grandpa had built a rear bumper on it that you could push trees down with, unfortunately the way it was mounted on the frame allowed it to trap all that evil Canadian road salt and alkali soil which proceeded to eat the frame where the rear shackle mounts attatch.
I'd appreciate any input/pics on what other guys have done to fix this problem. I don't want to do a frame off build at this point because I'll probably run out of cash halfway through and have a useless pile of money pit in my garage. I'm also thinking about doing a spring over, but I would like to try raising the front fenders and trimming the rears to fit 35s before I do it. It already has 32s with 2 1/2 inch lift springs and bigger shackles ,a spring over would make it too high.... maybe. Any thoughts? Power steering and disc brakes will be the next mod. And after removing the stock rollbar and seeing what it was mounted to, maybe a rollcage is needed! Still trying to decide on mini truck disc brakes or just swapping a disc brake front end in. I've heard about a 60 series swap but I'm not sure if it's just swapping in a 60 series axle or just the knuckles out.
I'm just getting started now, just cleaned the dirt off to see what's underneath and I'm looking for a mig welder so I can get started. I attatched some pics but I've never done this before so I'm not sure if they worked. I'm looking forward to all the help and ideas you guys can give me along the way. I'll try and post more pics when I get going.
I picked up some .188 wall 2x4 tubing to rebuild the back of the frame. The crossmember that the rear shocks mount to is suspect as well so it'll have to go, I just have to get some motivation and get back in the garage and start cutting. I'm still a bit hesitant to do this because the local Federales frown on homegrown frame repairs. Better not get pulled over I guess
